240vac to 24vdc (or 12vdc)
Scott
What is the name of the component that does this? I've tried a few searches but they have came up empty for what I am looking for. I want to attach a solar pump to one of my bits of homebrew kit, the solar pump I want to use needs 24v, or 12v, DC so I need some sort of inverter/transformer to do this. I just need the component, rather than a case, as it will be mounted inside the kit it's being attached to.
240Vac in, 24Vdc out :D
Cheers :)
Look for 24V DC switch mode power supplies on Ebay. The Chinese ones work fine, but choose an output at least 25% higher than you need as they tend to be optimistically rated.
I have some here and no issues. How many Amps does it draw?
Example:
http://www.ebay.co.uk/itm/24-volt-DC-power-supply-enclosed-switch-mode-24V-1-8A-40W-/320858784603?pt=LH_DefaultDomain_3&hash=item4ab4ac835b
or
http://www.ebay.co.uk/itm/24-volt-DC-2-7-Amp-Power-Supply-Unit-240v-AC-input-For-CCTV-Access-Control-etc-/331515030801?pt=LH_DefaultDomain_3&hash=item4d2fd5ed11
