which tyre size
Virus
It's worth checking with the tyre manufacturer, but I've seen 245 40 18 on an 8" wheel, and although they did fill the wheel out, they didn't balloon.
I would personally consider 245 the absoloute limit though, and a 235 will be a better fit. :)
235/30 R19 would be a total then? (i took a guess on the 30, i have no clue about tyre sizes)?
235/35R19 on the front would be closer to the stock circumference.
Use the tyre calculator I posted a link to earlier (http://www.willtheyfit.com/), it is very easy, in the 'YOUR EXISTING SETUP' put in the stock tyre information and in the 'YOUR NEW SETUP' put in the tyres sizes you want to compare, then press calculate.
