Possible Crank pulley issues
Scutch0
Hi guys, need a bit of advice.
I've started to notice a slight squeal when I start the supra and also blip the throttle. Initially I assumed the aux belt was just worn however it still does it after I've replaced it.
After doing a search on here a lot of people have been talking about crank pulley issues, my question is how can I diagnose this? And is it just a case of replacing the bottom crank pulley or does anything else need changing?
It is due a timing belt change very soon so I'll probably get my mechanic to do this at the same time, or I'll have a go at it myself.
As above, try that test.
If you do need a replacement, I'd stick with an OEM part though as they are harmonically balanced correctly; unless you're running big power and can afford something like a Titan crank pulley.
No need to go to Toyota - try whifbitz on here or tcbparts.co.uk
Also if a replacement is needed, are these lightweight sets a worthy replacement? As I dread to think what mr T is gonna charge me for one!
At the very least get the ones on eBay for £100-120 these are almost the same as stock. They don't have the balancing dimples you can see on the tipped test one pictured above though. I'd rather a stock used pulley than a solid alloy one.
We'll I've just found them on tcb parts for £198.57 + vat. Look in the engine parts section then select 'supra' and scroll down.
Russian roulette with buying used if you ask me. Could last you years or could give up within weeks/months
The damage caused by the crank pulley failing whilst driving will be more expensive than the cost of a new one! You seriously do not want one of them bouncing around the engine bay. Equally the pulley could find its way out of the bay and cause bodywork damage to the car or even others behind you!
There is an inner and outer part of the pulley and if the rubber between the two perishes enough, the inner one stays attached to the block via the bolt, but the outer one that the belt goes round just goes walkabout in your engine bay.
Guest Budz86
I have a used OEM one with less than 10k on it I'm selling. Very good condition, just needed an uprated one for my build. Only fitted this roughly 18 months ago. Looking for 180 plus postage
