Syvecs boost control solenoid and traction cal switch
johnd-mkiv
Nothing wrong with the Greddy - no need to replace unless it is faulty.
CAL switches on a Syvecs only need to be 2 wire, unless they "have" to be fitted to an input that doesn't have the integral pull up (applies to 4 of the 16 inputs; the "AV" type). A 3 wire type can still be supplied.
TC is usually an 8 way in my experience, or can be controlled via Toucan if you have one ;)
Didn't even realise you were on here Tim, I'm the "Scott" who's been bugging the life out of you on the Syvecs board :D
