mattdavies Posted March 24, 2015 Share Posted March 24, 2015 I have just fitted my Mines ECU from Keron. I would like to know what has been done to it but have not had any reply from Mines for over a week, I enquired using the online tool. Does anyone have a direct email address for Mines ? Maybe someone who has enquired with them before ? Quote Link to comment Share on other sites More sharing options...
Slam Posted March 24, 2015 Share Posted March 24, 2015 Try Jake. Think he got mines Quote Link to comment Share on other sites More sharing options...
ripped_fear Posted March 24, 2015 Share Posted March 24, 2015 Hi mate as above I have a mines ecu and despite contacting a few different ways with mines Japan I am not getting any reply. I will be looking into it again soon. Quote Link to comment Share on other sites More sharing options...
T2 MSW Posted March 24, 2015 Share Posted March 24, 2015 The only thing I know about them from seeing a car with one on a dyno is they have a much higher/no rev limit. There were a few members there on the day that saw a car bounce the wrong side of 8k. Was lucky it didn't go bang. Quote Link to comment Share on other sites More sharing options...
Guest Nicholas Posted March 24, 2015 Share Posted March 24, 2015 Have you tried [email protected] Matt? Quote Link to comment Share on other sites More sharing options...
gavin.starr Posted March 24, 2015 Share Posted March 24, 2015 Ive got a mines and have tried countless times to get info on my ecu and still nothing Quote Link to comment Share on other sites More sharing options...
mattdavies Posted March 24, 2015 Author Share Posted March 24, 2015 Have you tried [email protected] Matt? I have just dropped him and email to see if he could help IN regards to Rev limit, I certainly noticed that it revs higher, How does the Auto box know when to change gear ? is it a pressure thing or is it instructed by the ECU ? Quote Link to comment Share on other sites More sharing options...
ripped_fear Posted March 24, 2015 Share Posted March 24, 2015 I have purchased an ignition cut for mine to reinstate the OEM redline. Something to think about. Quote Link to comment Share on other sites More sharing options...
T2 MSW Posted March 24, 2015 Share Posted March 24, 2015 I remember thinking at the time 'thats the stupidest thing ever' as its too much of a risk to the engine IMO. One lapse of concentration or wheelspin under high boost and it could result in head components bouncing off your windscreen! Quote Link to comment Share on other sites More sharing options...
mattdavies Posted March 24, 2015 Author Share Posted March 24, 2015 I have purchased an ignition cut for mine to reinstate the OEM redline. Something to think about. How do you wire this in ? I understand you bought a bee*r did you look at any others such as Omex ? Quote Link to comment Share on other sites More sharing options...
MattP Posted March 24, 2015 Share Posted March 24, 2015 I'm sure the mines ECU completely removes redline unlike the stock VVTI which merely raises it a few hundred rpm. Quote Link to comment Share on other sites More sharing options...
Rob W Posted March 24, 2015 Share Posted March 24, 2015 I was lucky enough to get a response when I emailed them a few years ago. Just found the email, this was their info for my ECU. Hi Rob, Here's a spec of your ecu Fuel mapping and ignition timing optimized Speed limiter cut Rev limit +500 from stock With use of aftermarket boost controller set up to 1.10kg/cm2 Written for use with only OEM air cleaner(closed type air cleaner). Written for use with 100 ron octane rated fuel Best regards, Shin. MiNE'S The car has always been more responsive with this fitted, was worth the money IMO. Quote Link to comment Share on other sites More sharing options...
SPG Posted March 24, 2015 Share Posted March 24, 2015 I was lucky enough to get a response when I emailed them a few years ago. Just found the email, this was their info for my ECU. Hi Rob, Here's a spec of your ecu Fuel mapping and ignition timing optimized Speed limiter cut Rev limit +500 from stock With use of aftermarket boost controller set up to 1.10kg/cm2 Written for use with only OEM air cleaner(closed type air cleaner). Written for use with 100 ron octane rated fuel Best regards, Shin. MiNE'S The car has always been more responsive with this fitted, was worth the money IMO. Pretty much the identical response I received from Mines. Only difference was they wrote that it was configured to run supporting breathing mods. Exhaust etc Quote Link to comment Share on other sites More sharing options...
mattdavies Posted March 24, 2015 Author Share Posted March 24, 2015 Pretty much the identical response I received from Mines. Only difference was they wrote that it was configured to run supporting breathing mods. Exhaust etc Does it have a returnable email address ? Quote Link to comment Share on other sites More sharing options...
pedrosixfour Posted March 24, 2015 Share Posted March 24, 2015 Quote Link to comment Share on other sites More sharing options...
Graham1984 Posted March 24, 2015 Share Posted March 24, 2015 I had a reply back from Mines the following day when I contacted them. Regarding the redline IMO unless you are a complete helmet, you won't have a problem with changing gears, unless of course you have an extremely high powered single you would be absolutely fine as you are. Quote Link to comment Share on other sites More sharing options...
SPG Posted March 24, 2015 Share Posted March 24, 2015 I will have a look for the email Quote Link to comment Share on other sites More sharing options...
mattdavies Posted March 24, 2015 Author Share Posted March 24, 2015 I will have a look for the email Cheers Quote Link to comment Share on other sites More sharing options...
boostman Posted March 24, 2015 Share Posted March 24, 2015 I had a reply back from Mines the following day when I contacted them. Regarding the redline IMO unless you are a complete helmet, you won't have a problem with changing gears, unless of course you have an extremely high powered single you would be absolutely fine as you are. I still haven't put mine in yet, although I did message mines and they never got back to me. I know you said raised redline and more aggressive fuel but wanted more specific info if they had it? Don't suppose you've still got there reply? Quote Link to comment Share on other sites More sharing options...
Graham1984 Posted March 24, 2015 Share Posted March 24, 2015 I still haven't put mine in yet, although I did message mines and they never got back to me. I know you said raised redline and more aggressive fuel but wanted more specific info if they had it? Don't suppose you've still got there reply? It's just the usual raided rev limit, optimised fueling and timing, mapped for 100ron and that's it. Hopefully it works well, good bit of kit for a NA. Quote Link to comment Share on other sites More sharing options...
boostman Posted March 24, 2015 Share Posted March 24, 2015 It's just the usual raided rev limit, optimised fueling and timing, mapped for 100ron and that's it. Hopefully it works well, good bit of kit for a NA. Ok, will give it a go soon, opened it up and it was clean inside, no indication of any water or dry looking joints which is good. Quote Link to comment Share on other sites More sharing options...
LasseV Posted March 31, 2015 Share Posted March 31, 2015 It's just the usual raided rev limit, optimised fueling and timing, mapped for 100ron and that's it. Hopefully it works well, good bit of kit for a NA. I absolutely love my Mines ecu for n/a sup. It is brilliant piece of kit. It was broken tho, condensators were bad but local shop did fix it cheaply. I cant recommended these enough, i think these are must buy for every n/a owner who are interested to get more performance out of their car. Quote Link to comment Share on other sites More sharing options...
Guest Sausage Posted March 31, 2015 Share Posted March 31, 2015 I'm interested in this too. I found out mine had one other day and it seems a lot more of a hand full with bpu than any other supra's ive drove same spec - the ecu. Plus how fast dose a supra with bpu's go. Mines auto 180mph at about 6500rpm and still pulling not like a train but still going. Quote Link to comment Share on other sites More sharing options...
Chris Bailey Posted March 31, 2015 Share Posted March 31, 2015 I'm interested in this too. I found out mine had one other day and it seems a lot more of a hand full with bpu than any other supra's ive drove same spec - the ecu. Plus how fast dose a supra with bpu's go. Mines auto 180mph at about 6500rpm and still pulling not like a train but still going. Are you admitting you've done 180mph on an open forum? Quote Link to comment Share on other sites More sharing options...
