msupra1 Posted March 24, 2015 Share Posted March 24, 2015 Car is getting new cams and in the process I'm going to go ahead and refurbish my cam covers and whole intake manifold. I have done a lot of DIY paint projects under my belt including plenty sets of rims but I'm unfamiliar on the process for high-heat engine parts. Is there some sort prep work needed? you generally sand something down before painting it but wouldn't think this applies to something like a manifold. Just clean them good, high heat primer, and high hear paint? cheers Trying to go for a finish like this http://img.photobucket.com/albums/v99/cvc9216/IMG_5020.jpg Quote Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted March 24, 2015 Share Posted March 24, 2015 You don't need high heat paint, if you used to painting then just clean as normal and use 2K, it will stand engine temps no problem. Quote Link to comment Share on other sites More sharing options...
