mrboomberang Posted March 23, 2015 Share Posted March 23, 2015 10 mins ago felt and heard a strange noise and feel from steering a lot stiffer sometimes hear a strange buzzing noise on start up ? Quote Link to comment Share on other sites More sharing options...
heckler Posted March 23, 2015 Share Posted March 23, 2015 10 mins ago felt and heard a strange noise and feel from steering a lot stiffer sometimes hear a strange buzzing noise on start up ? have a look in the PAS resevior. see if there are any bubbles in there. - probably will need to bleed the system Quote Link to comment Share on other sites More sharing options...
mrboomberang Posted March 23, 2015 Author Share Posted March 23, 2015 Cheers heckler Quote Link to comment Share on other sites More sharing options...
evinX Posted March 23, 2015 Share Posted March 23, 2015 Power steering fluid for sure! mine had these symptoms and I lost steering through town one day. Driving a supra with out PAS is probably like driving a tank. Just get some 8mm and 16mm pipe + fluid and flush it all out. Youll see how nasty it is. Amazing what that fluid can do! Quote Link to comment Share on other sites More sharing options...
mrboomberang Posted March 23, 2015 Author Share Posted March 23, 2015 Cheers will do this tomorrow Quote Link to comment Share on other sites More sharing options...
mrboomberang Posted March 23, 2015 Author Share Posted March 23, 2015 Is it a specific type of fluid I need or just run of the mill stuff Quote Link to comment Share on other sites More sharing options...
Hitbox Junkie Posted March 23, 2015 Share Posted March 23, 2015 http://www.mkivsupra.net/vbb/showthread.php?56684-FAQ-Oil-Fluid-Interval-Capacity-Steering-Brake-Coolant-Diff-Engine All the fluid information in one spot This was taken from the link above all credit to that man! "Power Steering Fluid Stock Dexron III ATF I recommend you stick with Dexron III oil but all makes should be suitable Capacity Interval = ??? To fully Flush it see here" Quote Link to comment Share on other sites More sharing options...
mrboomberang Posted March 23, 2015 Author Share Posted March 23, 2015 Cheers for that just checked out how to change it seems simple enough getting the juice bottle ready yes will buy dextron 3 Quote Link to comment Share on other sites More sharing options...
Virus Posted March 23, 2015 Share Posted March 23, 2015 Had something similar not so long ago, this started leaking & had no PSF left in the reservoir Keron supplied me with the replacement & worked like a charm. Quote Link to comment Share on other sites More sharing options...
mrboomberang Posted March 23, 2015 Author Share Posted March 23, 2015 I will have a good check round it tomorrow before I start anything Quote Link to comment Share on other sites More sharing options...
Glanza_Mike Posted March 23, 2015 Share Posted March 23, 2015 I have this problem too, so ill do this on the weekend. Quote Link to comment Share on other sites More sharing options...
mrboomberang Posted March 24, 2015 Author Share Posted March 24, 2015 A couple of pics from power steering Quote Link to comment Share on other sites More sharing options...
mrboomberang Posted March 24, 2015 Author Share Posted March 24, 2015 Just took it a run after doing the fluid change steering seems sweet as Quote Link to comment Share on other sites More sharing options...
