decat to twintubo supra
jza800
i am gonna raise the boost to 1.2 bar, and keep the 1st cat, and remove the 2nd cat with the decat pipe, with the time i gonna remove the 1st cat.. so if i fit a 2" restrictor ring, can i still hit the target boost??
Don't run 1.2bar with a cat in place. Mine occasionally hit 1bar with the 1st cat in place, but only very cold weather when the air was dense.
Remove both cats, fit a restrictor ring, if you need to fit a cat for MOT purposes, switch the boost controller off if you intend to hit full boost.
So do you need a restrictor ring with a boost controller if you have both cats removed and want to run at a switchable 1 bar and 1.2 bar
It's advisable. A boost controller can only raise boost, not lower it. With no restrictor ring you would have no lower limit, so it could easily overboost.
Over boostcand detonation would not be fun.
Cheers for the advice and sorry for hijacking the thread.
You should still pass an MOT with no cats fitted.
No you won't, it's an instant failure.
The rules changed last year to include a visual inspection as well as the emissions test. If you have removed the cat(s) = fail.
Mine failed for this reason so I had to buy an old cat...
Search for MOT rules, I posted a link sometime back to the official bumf'
- - - Updated - - -
Or depending on the garage they plug the probe into a nice Audi diesel or something for the emissions test :D
Looks like we'll all follow you to your garage then :)
