How to fit a chris wilson fcd to a vvti tiptronic
wile e coyote
Ok fitted this today so did a how to
Now if you follow this and break something I take no responsibility
DISCONNECT BATTERY BEFORE COMENCING
Diagram will help with the pin outs
attachment.pdf
Now im sure your able to get to the ecu which is in the passenger footwell
when removed cover you should then see this
The black wire has an eyelet attached so you can bolt this to the 10 mm bolt holding the ecu
Now splice in the red wire to pin 9 on (block 78 6th from left) which is Black and red( switching battery power )
Now locate pin 9 on (Block B75 2nd from left) Black and yellow (yellow may have faded and looks whitish ) cut it aprox 2" from ecu
Now attach the green wire from fcd to ecu side nearest block of wire you just cut
Now attach the white wire to map sensor (pm1) side that goes into loom of wire just cut
Tidy up wiring and secure fcd ( I zip tied it to the loom on left)
Reconnect blocks and secure ecu and refit cover and carpet
Connect battery and all done
Thanks Darren
Edited by wile e coyote (see edit history)
  • 4 weeks later...
  • 9 months later...
  • 4 weeks later...
