stock boost on a 2jzgte?
Guest vansterdam731
Guest vansterdam731
ok i got 1993 jdm 2jzgte...bigger downpipe,bigger intercooler and piston done..
i have a boost controller and i have the setting off...i want to run stock boost..
i was told stock boost was around 10psi..but in 3rd gear i am running around 17psi to 20psi..
can someone tell me why this is happening?
A boost controller can only increase boost, not decrease it. The standard exhaust limits the amount of exhaust gasses going through the turbos. Because you have increased the flow of the exhaust your boost has increased. Be carefull if you're on standard injectors and fuel pump etc
Guest vansterdam731
so are u guys saying for my supra to go back to stock boost ...i have to change my car back to stock parts?
