alwaysflat Posted March 18, 2015 Share Posted March 18, 2015 (edited) Ok so car had heater matrix problem. Now the interior light has no delay. When you shut the door it goes out. And no footwell light ignition hole light or door key hole light. Also cruise control no longer works ive had steering wheel off and cruise plug is connected. Dont know where else to look. Mechanic says maybe ecu got wet but not really believing that. Feel a bit messed about! Any help would be great. Thanks in advance. Actually ignition barrel light does work but goes out as soon as door is shut. Likewise door handle light. So just no delay!! Edited March 18, 2015 by alwaysflat (see edit history) Quote Link to comment Share on other sites More sharing options...
chrispot Posted March 18, 2015 Share Posted March 18, 2015 was the heater matrix replaced? as i believe thats a dash out job, as it working before sorting heatér. i did not supras had a interior lamp delay, my car is done through the alarm system. if your mechanic took the dash out and interior light was working before and not ẃorking would seem to be his fault, from memory i think the cruise ecu is in the middle of the dash, and when matrix leaks its on the n/s floor. have you checked fuses regards chris Quote Link to comment Share on other sites More sharing options...
alwaysflat Posted March 19, 2015 Author Share Posted March 19, 2015 Thanks chris Quote Link to comment Share on other sites More sharing options...
