NA map sensor help
Guest SnaillessJZA80
So I've had an interesting morning. Drove to the shops the morning, car was behaving as usual, no signs of any problems, then when I jumped in to drive home I was met with a horrible idle, a engine check light and a heap of black smoke coming out the back... Managed to limp it home (wasn't fun) and now it's parked in the shed. From what I've found this sounds like a map sensor (labeled sensor assy, vacuum) failure. What I was hoping to find out is that is there a way to check if it's the sensor itself, or whether somewhere along the line a wire has decided to shit itself?
Cheers.
Part no on the map is 89420-14080, dunno of that matters.
Did the diagnosis bridging te1 and e1 and no codes were shown. Hopefully going to get a proper diagnostic tool off a friend of my dads sometime soon though so hopefully I'll be able to see how everything is working
Edited by SnaillessJZA80 (see edit history)
  • 5 weeks later...
Sorry, been really busy with uni and the supra has sat in the shed for the last Month... I checked the hose coming off the sensor, its completely fine. Does anyone know where I could find a wiring diagram or something that shows what sort of voltage / resistance I should be looking for going into the sensor so I can check if it's the sensor itself or if it's not getting the right signal to it? Thanks
