walkerstrider Posted March 15, 2015 Share Posted March 15, 2015 Keep getting 4 lights appear on my 94 na j spec. The battery symbol the one to the right of it the orange exclamation mark and the oil light. There are no other obvious problems like lack of power electrical or mechanical. They do seem to go off under harsh acceleration but then come on again a few minutes later. Any ideas what this could be? Link to comment Share on other sites More sharing options...
Morzy2k5 Posted March 15, 2015 Share Posted March 15, 2015 I would check the basics first like all earth points.they are known for having dry solder joints on that little circuit board also so you might want to check that out aswell where the oil light is etc. Link to comment Share on other sites More sharing options...
walkerstrider Posted March 16, 2015 Author Share Posted March 16, 2015 Cheers mate, cant see anything obvious. Drove 27 miles down to work this morning no warning lights. About 5 mins into the journey home they came on again. Doesnt seem to be any rhyme or reason to why they keep doing it. Im at a loss. Link to comment Share on other sites More sharing options...
Scooter Posted March 16, 2015 Share Posted March 16, 2015 Sometimes an indication of a soon to expire alternator.... Link to comment Share on other sites More sharing options...
walkerstrider Posted March 16, 2015 Author Share Posted March 16, 2015 Just been replaced, obviously ive checked all the connections. That was about 3 weeks ago iits been fine since. Link to comment Share on other sites More sharing options...
j_jza80 Posted March 16, 2015 Share Posted March 16, 2015 Crank pulley or belt? Link to comment Share on other sites More sharing options...
walkerstrider Posted March 16, 2015 Author Share Posted March 16, 2015 Belt looks fine, theres no slipping noise. How do I check the crank pulley? Link to comment Share on other sites More sharing options...
Slam Posted March 16, 2015 Share Posted March 16, 2015 Alternator Link to comment Share on other sites More sharing options...
trebor69 Posted March 16, 2015 Share Posted March 16, 2015 Belt looks fine, theres no slipping noise. How do I check the crank pulley? Tipex line down the pulley then run it and keep an eye on the line separating/moving. Link to comment Share on other sites More sharing options...
Digsy Posted March 16, 2015 Share Posted March 16, 2015 Definitely alternator symptoms, except you say you've changed it out already. The lights I had when mine went were oil level (yellow light) first, (went out wen revs increased). Then catalyst temperature, then ABS warning and last of all the actual alternator / battery light. Link to comment Share on other sites More sharing options...
Al Massey Posted March 16, 2015 Share Posted March 16, 2015 Do the tipex test straight away. My money is on that Link to comment Share on other sites More sharing options...
walkerstrider Posted March 17, 2015 Author Share Posted March 17, 2015 Cheers guys, got a feeling it might be the crank pulley. Had the car 18 months and it's always had a strange noise on tickover like a skimming noise. Seems to be coming from this area, goes when revs are raised so gonna change it anyway. Hopefully it will sort it. Link to comment Share on other sites More sharing options...
Al Massey Posted March 17, 2015 Share Posted March 17, 2015 Do a tipex test first Otherwise you're spending money and time for nothing Link to comment Share on other sites More sharing options...
walkerstrider Posted March 17, 2015 Author Share Posted March 17, 2015 (edited) OK just done the tippex test. Warmed car up and had a look but the line hasn't budged! Lights are still on. Battery light, cat light, orange exclamation box and oil can with squiggly line. All at once. Edited March 17, 2015 by walkerstrider (see edit history) Link to comment Share on other sites More sharing options...
Chris Wilson Posted March 17, 2015 Share Posted March 17, 2015 Measure the battery voltage with plenty of electric stuff turned on, at a fast idle. Should be circa 13.8V Link to comment Share on other sites More sharing options...
walkerstrider Posted March 17, 2015 Author Share Posted March 17, 2015 Not got a voltmeter but I do have a spare battery which im gonna try once ive put some charge in it Link to comment Share on other sites More sharing options...
walkerstrider Posted March 17, 2015 Author Share Posted March 17, 2015 Well turns out my spare battery was knackered so I went and bought a volt meter. With everything on it read 11.12. With everything turned off it read 11.48. This was on tickover. I'm assuming I need a new battery? Link to comment Share on other sites More sharing options...
RobUK Posted March 17, 2015 Share Posted March 17, 2015 Well turns out my spare battery was knackered so I went and bought a volt meter. With everything on it read 11.12. With everything turned off it read 11.48. This was on tickover. I'm assuming I need a new battery? Would appear so... Where did you measure from? I had problems with poor connections in the past that appeared to be battery but was actually a poor connection... Link to comment Share on other sites More sharing options...
walkerstrider Posted March 17, 2015 Author Share Posted March 17, 2015 Would appear so... Where did you measure from? I had problems with poor connections in the past that appeared to be battery but was actually a poor connection... Top of battery terminals so won't be poor connections. Raised idle speed and it dropped to 11.0 Link to comment Share on other sites More sharing options...
Chris Wilson Posted March 17, 2015 Share Posted March 17, 2015 No, you need a new alternator, or the alternator wiring is faulty. Link to comment Share on other sites More sharing options...
walkerstrider Posted March 17, 2015 Author Share Posted March 17, 2015 Recently changed the alternator, was fine for couple of weeks but it was quite oily and ive noticed an oil leak around the distributor which looks like its dripping straight into the 3 pin plug on top of the alternator. Tried to wipe it out but hasnt made any difference. Link to comment Share on other sites More sharing options...
Slam Posted March 17, 2015 Share Posted March 17, 2015 Have you done a test on alternator. Link to comment Share on other sites More sharing options...
walkerstrider Posted March 17, 2015 Author Share Posted March 17, 2015 Have you done a test on alternator. Wouldnt know where to start. Link to comment Share on other sites More sharing options...
walkerstrider Posted March 17, 2015 Author Share Posted March 17, 2015 Ive also checked the condition of the 120 amp fuse which doesnt look too good. The plastic covers missing and the arched terminal inside looks all white and crusty. Could this be a cause? Link to comment Share on other sites More sharing options...
walkerstrider Posted March 19, 2015 Author Share Posted March 19, 2015 Just a quick update, after breaking down on the way to work and having to use a ford garage of all places! Had the alternator test and it turns out the alternator failed for a second time! Thanks for all the input tho, its always appreciated. Link to comment Share on other sites More sharing options...
