rob wild Posted October 26, 2015 Author Share Posted October 26, 2015 Then last weekend I did the showdown event which was 15 GTR vs 15 Skylines in a head to head 3 event battle Here's a few videos http://youtu.be/UplI6cb2I-k Must say 7000rpm launches were fun Quote Link to comment Share on other sites More sharing options...
rob wild Posted October 26, 2015 Author Share Posted October 26, 2015 One of the first dyno runs at 1.28 bar 412 ATWHP Quote Link to comment Share on other sites More sharing options...
j_jza80 Posted October 26, 2015 Share Posted October 26, 2015 I bet Cadwell was so much fun! Such a nice car. Quote Link to comment Share on other sites More sharing options...
Chris Bailey Posted October 26, 2015 Share Posted October 26, 2015 Love it Quote Link to comment Share on other sites More sharing options...
rob wild Posted October 27, 2015 Author Share Posted October 27, 2015 I bet Cadwell was so much fun! Such a nice car. Yeah Cadwell was great Love it Cheers dude:) Quote Link to comment Share on other sites More sharing options...
Luxluc Posted October 27, 2015 Share Posted October 27, 2015 Nice result mate. Quote Link to comment Share on other sites More sharing options...
rob wild Posted November 15, 2015 Author Share Posted November 15, 2015 So the car is currently perfect with no issues So now I've proved to myself its a good base car I want to bring it up to more modern standards with a 500whp build. The idea is to focus on great response fast road / track build. Stage 1 will be to swap the current turbo set up for a small single. Just bought one of these So looking at Tial MVS 44mm wastegates and either BorgWarner EFR 8374 or Precision 6262. Also planning some other mods with it so I can switch between vent to atmosphere or re-circulate. Then adding the Link G4+ with a focus on Launch, Anti Lag and flat shift. I'm also looking at adding HKS VCAM, just need to get a good price. Quote Link to comment Share on other sites More sharing options...
j_jza80 Posted November 15, 2015 Share Posted November 15, 2015 Nice Will be interested to see your plans for the wastegate recirc, I was thinking about something like this too, but couldn't see a neat way of doing it. Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted November 15, 2015 Share Posted November 15, 2015 Why not use the GTS-t cam timing actuator? I can supply all the bits including custom ground cam and solenoid etcetera. It can even be installed without lifting the head. Flat shift on a stock gearbox? Hmmmm.... Quote Link to comment Share on other sites More sharing options...
GazDoran Posted November 15, 2015 Share Posted November 15, 2015 Very interested to see how you get on if you go with the current 6262 as that's the route I plan to take on my Supra in the hopefully not too distant future. Quote Link to comment Share on other sites More sharing options...
rob wild Posted December 20, 2015 Author Share Posted December 20, 2015 So little update, the car is going first week of Jan for the new single set up so thought I'd work on some custom OBD DIY CAN. So had a busy morning and did the following. So started off soldering the hardware (thanks to the sister in law for the early xmas presents lol) No my best soldering, but everything works and I'll tidy up later! So to the coding decided to go with a CANBUS.h lib's which use the MCP2515 chipset. Only really as I like the concept of using ecu request (I understand that this is only a layer of abstraction and the MCP functions are still capturing frames). Also there is no need for any front end PID filtering. Unfortunately the CANBUS lib aren't that well documented nor is the hardware. So I had to do some editing of the core lib's what a PITA!!! However the main advantage is keeping the main loop tidy for example:- void loop() { Canbus.ecu_req(RPM, Buffer); intRPMvalue = atoi(Buffer); drawRPMValue(intRPMValue); } (borrowed your draw function Alex and rewrote parts to suite, hope you don't mind ) So did a bit of testing with the Wife's Nissan JUKE Nismo RS and then in my XFR. Seem to work fine in both:- Not the best photos but you get the idea! So offered a good friend some of my homemade Mince pies lol and he let me use his Cube 3D printer So he just dropped off what will be an Air vent enclosure, this was fairly simple to do i.e. sketchup then export to stl. So going to use 2 of these with the JST header to connect to the Link Also ordered a power regulator and a smaller 1.8" screen which I might mount behind the clock. So moving forward I'm going to 3d print the buttons with the intention of that I'll allow the user (me) to scroll through 4 values (Boost, RPM, MPH, AFR) with the idea that the screen will show peak and current. Going to include a nice GTR image on start up post can bus initialize. Quote Link to comment Share on other sites More sharing options...
j_jza80 Posted December 20, 2015 Share Posted December 20, 2015 Fantastic work Quote Link to comment Share on other sites More sharing options...
Ian C Posted December 21, 2015 Share Posted December 21, 2015 Now THAT is modding! Quote Link to comment Share on other sites More sharing options...
rob wild Posted December 21, 2015 Author Share Posted December 21, 2015 Thanks chaps just working on some meters I'll post a video shortly Quote Link to comment Share on other sites More sharing options...
Chris Bailey Posted December 21, 2015 Share Posted December 21, 2015 Wow that looks confusing! Fair play to you for taking on a job like that . Quote Link to comment Share on other sites More sharing options...
rob wild Posted December 22, 2015 Author Share Posted December 22, 2015 Just testing the meter view for rpm, afr and boost Quote Link to comment Share on other sites More sharing options...
rob wild Posted December 23, 2015 Author Share Posted December 23, 2015 Popped a new Head unit in the old R32 as the other one broke so I went with android This connects to my Link G4+, what do you think? Quote Link to comment Share on other sites More sharing options...
Wez Posted December 24, 2015 Share Posted December 24, 2015 Very cool Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted December 24, 2015 Share Posted December 24, 2015 Remarkable, well done! Quote Link to comment Share on other sites More sharing options...
rob wild Posted January 9, 2016 Author Share Posted January 9, 2016 Very cool Remarkable, well done! Cheers chaps it's really starting to come together! Quote Link to comment Share on other sites More sharing options...
rob wild Posted January 9, 2016 Author Share Posted January 9, 2016 So dropped it off for its single setup. Went for the following spec Raw brokerage manifold twin scroll Twin Open and re-circed screamer Turbo wise went with a Garret gtx 35r Tial mvs 38mm twin gates 3 1/2 inch down pipe Link G4+ with a aircraft style high low boost switch Power goals wise Andy @ Speedtech is fairly confident of 600 fwhp but I want mega response! Updates very shortly as Me and Sted are doing Silverstone on the 15th of Feb!!! Can't wait!!! Quote Link to comment Share on other sites More sharing options...
rob wild Posted February 17, 2016 Author Share Posted February 17, 2016 So just a quick update New spec list Updated Spec list Engine Complete engine overhaul Trust sump Extension Trust front diff cover After market oil pump HKS step one 264 camshafts HKS adjustable cam pulleys HKS 1.2mm head gasket HKSi inlet and exhaust gasket kit HKS/Greddy intercooler piping kit Trust front pipe Samco top radiator hose Custom hard pipe kit Kakimoto exhaust De-cat pipe Rawbrokage Twin Scroll divided Manifold BW EFR 7670 internal wastegate, blow off valve, twin scroll 3" Downpipe K&N Airfilter Fueling 660cc Denso Injectors Greddy fuel rail Auto Staff fuel pressure regulator with fuel pressure gauge Nismo in tank fuel pump Cooling Greddy Intercooler ARC alloy radiator ARC air separator tank Grex oil filter relocation kit Greddy Oil cooler kit Brakes/Suspension/Drive Rebuilt gear box at time of engine build NISMO copper mix clutch (very easy to use) Cusco rear LSD Trust larger capacity rear diff cover AP 6 pot front callipers good discs and pads. Braided brake lines Apexi coilovers Cusco front and rear anti roll bars Adjustable pillowball lower and top arms (very rare) Front adjustable top arms After market front tension rods Interior/CPU/Controllers Link G4+ Android Flip out HU Hesemi racing bucket seats Sparco steering wheel Exterior 18***8221; Works Emotion alloy wheels Michilen Cup2 tyres Nismo rear spoiler lip __________________ - - - Updated - - - Just a quick update after doing some testing at Silverstone. First thing, this new set up is seriously good and makes for a very enjoyable, fresh, modern, punchy drive. I must say in hindsight I should have waited and taken my Teg to Silverstone, for a few different reasons but mainly the combo of Cup2 tires in less than 2deg, with still icy parts of the circuit meant I had to be very careful when letting the power in. So after a while of trying to push on and the car sliding I decided to just back off. However I felt the car was much more controllable with this set up as its very progressive making full boost 1.45 bar by 3900rpm. One thing I really noticed was on the motorway, just cruising at say 2000-2500rpm as soon as you touch the throttle its boosting. Just for reference I over heard in the pits that the car in front had been remapped so probably 700hp and with traction control lol Yes I know my lines weren't great and I was being very careful with my throttle input! I can't wait for May as I'm going to take both the Teg and the 32 to Cadwell! So moving forwarding with the car, still thinking about engine swaps might go RB30 with it. Andy's got a few tweaks to do with the car (rolling launch lol) and I'll post the dyno print comparing it to the twin setup However so far stock engine FTW Quote Link to comment Share on other sites More sharing options...
j_jza80 Posted February 17, 2016 Share Posted February 17, 2016 That's just fantastic Personally I wouldn't go RB30, it just seems to loose a bit of the RB26 screaming nature. Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted February 17, 2016 Share Posted February 17, 2016 Very nice. I have just finished an engine rebuild on an R33GTR and on fire up found a bad oil leak, whilst it was still on the ramp. The no brand, Japanese after market 25 row oil cooler had split. Luckily I saw it immediately and it was only weeping. Mustn't have liked the fresh build oil pressure... Would have been nasty had it happened on the road. Engine damage and the possibility of hot oil all over the LH front tyre. Awaiting a new Setrab cooler. White's the best colour! Quote Link to comment Share on other sites More sharing options...
rob wild Posted February 17, 2016 Author Share Posted February 17, 2016 That's just fantastic Personally I wouldn't go RB30, it just seems to loose a bit of the RB26 screaming nature. Yeah it was pretty epic lol Yeah I know what you mean about the 30's just want more torque and build something that could take 700hp Very nice. I have just finished an engine rebuild on an R33GTR and on fire up found a bad oil leak, whilst it was still on the ramp. The no brand, Japanese after market 25 row oil cooler had split. Luckily I saw it immediately and it was only weeping. Mustn't have liked the fresh build oil pressure... Would have been nasty had it happened on the road. Engine damage and the possibility of hot oil all over the LH front tyre. Awaiting a new Setrab cooler. White's the best colour! Cheers Chris do like it in white! Love to see some photos of the R33GTR engine build, what spec did you build? Have you built many Rb30's? Quote Link to comment Share on other sites More sharing options...
