12 bolt Diff Pinion Torque
Jellybean
Hi
http://www.mkivsupra.net/vbb/content.php?75-Suspension-Axle
I am looking through the repair manual here , but it refs the small case diff ; what is the torque for the Pinion nut?
Its a 2jzgte , 12 bolt 220mm pin and ring gear (Large case diff) with a Carbonetic LSD
SA75
Pinion Gear Backlash: 0.05 – 0.20 mm (0.0020 – 0.0079 in.)
Ring Gear Bolts Torque: 64 N·m (650 kgf·cm, 47 ft·lbf)
Drive Pinion Preload New bearing preload (at starting) 2.0 – 2.5 N·m (20 – 25 kgf·cm, 17.3 – 21.7 in.·lbf)
DIFFERENTIAL CARRIER RETAINERS Torque: 22 N·m (225 kgf·cm, 16 ft·lbf)
Ring Gear backlash Backlash (average value):0.08 – 0.13 mm (0.0031 – 0.0051 in.)
Diff carrier cover 78 N·m (800 kgf·cm, 58 ft·lbf)
Breather plug Torque: 21 N·m (210 kgf·cm, 15 ft·lbf)
