My Supra TT Widebody
Supratoc1990
as ye can see from the photo directly above the bonnet wasn't sitting correctly on the left/passenger side.
so naturally had to get that sorted thankfully it was because the hinge on the actual bonnet was back to front.
[ATTACH=CONFIG]198956[/ATTACH]
as ye can see all sorted now thankfully
after that I joined this forum and got ganador wing mirrors
and when sprayed and fitted
then because it was standard on the front suspension wise.
went out and got tein coilovers
and then got bride rails from Japland
and seats finally fitted
ara getting a few bits done alright small things but I like how its coming along still not fully up to date but its not to bad now and will only get better in time
as for the arches yes you read it correct unfortunately in away.
to give you a straight answer if I had spare money then yes I would do it in a heart beat but il stick to doing up small little things at a time small performance things if I can
but in time yes I hope to do that ....
right lads after the exhaust went on or went to be fitted. then THE PROBLEMS started
I brought it to a garage where I thought they were very reputable unfortunately I was wrong
botch job
[ATTACH=CONFIG]198851[/ATTACH]
[ATTACH=CONFIG]198852[/ATTACH]
got a hammer and beat it in line with the rear diffuser which was hideous
tell me what yous think???
I got it fixed thank god
[ATTACH=CONFIG]198853[/ATTACH]
That is so typical of pretty much any garage in Ireland!
Don't give a shit
im from the west side of mayo mate. went to ballina which is about an hours drive then on to galway followed by clare galway looking for a decent mechanic and after all that searching and looking and getting kinda shafted at most if not all I found a mechanic 10min away from myself and he is top notch and his work is second to none , wouldn't bring the car to anyone else now at this stage...
