hand grip thing and roof lights
Virus
Yeah figured as much but it seemed really firmly stuck (got the right side out, but not the left side, figured maybe a little screw). The new one i got doesn't seem as nearly as stuck as this one lol.
Any ideas for the hand grip thing (or how ever you call it?) Not even sure if this comes stock with supras
The light is screwed in, pop the light lense out with a small flathead screwdriver and there is two starhead screws to remove inside then it should just drop away from the roof
The jesus handle you push in and pull the bottom downwards in a sliding motion then once the lower is out the bracket push the top upwards it should slide upwards, theres a bolt on each bracket hidden behind the handle you remove to release the small spacers and brackets
Edited by safcdixon (see edit history)
I tried pushing it out but it doesn't "unhook" from the clip if you know what i mean. I seen where the screw is though but can't seem to reach it properly :/
