Supra2jze Posted March 9, 2015 Share Posted March 9, 2015 Hi guys, If anyone could help guide me on the following. I've purchased Genuine BBS LM 19" 5 x 100 stud diameter, was wondering what adapter would be required in order to fit my Supra. I'm aware Supra's are 114.3 but which PCD would you guys recommend? Thanks Link to comment Share on other sites More sharing options...
j_jza80 Posted March 9, 2015 Share Posted March 9, 2015 Sell them and buy some with the correct PCD. Because yours are the highly desirable 5x100, they will be worth more than a set in 5x114.3. Link to comment Share on other sites More sharing options...
tkddav3 Posted March 9, 2015 Share Posted March 9, 2015 You have to get 5x114.3 don't you? Otherwise you'll be using wobble bolts and as you'll already have to use hub adapters you may aswell get the correct pcd anyway Well that's what I assume anyway mate Link to comment Share on other sites More sharing options...
Mk4Gaz Posted March 9, 2015 Share Posted March 9, 2015 You can't use wobble bolts on a supra, they use wheel nuts, not bolts Sell them, and buy correct fitting wheels as mentioned above Link to comment Share on other sites More sharing options...
Swampy442 Posted March 10, 2015 Share Posted March 10, 2015 If you want adapters you need 5x100 to 5x114 stud pattern. but depending on the offset the wheels might not fit. As above, sell and get the correct pcd. Link to comment Share on other sites More sharing options...
