Scott Posted March 9, 2015 Share Posted March 9, 2015 I feel that this is probably a stupid question so I've left it out of Technical in case Ian C has palpitations lol. I've no idea who configured the Syvecs I have originally but they haven't half made a mess of it. So many wrong things chosen and selected in the inputs that it's thrown me way off when trying to configure it to my setup. For the record, it definitely wasn't Ryan lol. Anyway, it's brought about a couple of queries that I would just like to have the information on. How does the ECU use the IAT sensor? Does it adjust the fueling based on the charge temperature? I guess this is the case, after all we all know that colder air = more O2. Additionally, does the Syvecs do this automatically or is this something else that needs configured? The calibration for the sensor is all done, I just need to select the correct pinout. What I don't know, is if it will automatically start using the readings from the sensor once I have done this. Next, as above, how does the ECU use the vehicle speed sensor? Does the ECU send the speed to the speedometer, or is it an independent signal? What does it take into account regarding the speed? What is it used for? The only thing I could think of would be traction control? I'm probably missing out something obvious though. Thanks Quote Link to comment Share on other sites More sharing options...
Wez Posted March 9, 2015 Share Posted March 9, 2015 It will have fuel corrections located at > Run-Mode fueling / corrections / Air Charge Temp Multiplier. Also ignition corrections located at > Run-Mode ignition / corrections / Air Charge Temp Multiplier. From Memory the clock cluster gets its speed inputs from the gearbox, when setting up traction control you can wire some convertors into the ABS sensors so that the syvecs sees the correct signal for wheel speed, on a MKIV normally two rear and one front since both fronts should be travelling the same speed or if you have enough inputs then both fronts too, I cant remember 100% its been a while Quote Link to comment Share on other sites More sharing options...
Wez Posted March 9, 2015 Share Posted March 9, 2015 I have just checked an old calibration and I am showing four speed sensors wired in. Quote Link to comment Share on other sites More sharing options...
Scott Posted March 9, 2015 Author Share Posted March 9, 2015 It will have fuel corrections located at > Run-Mode fueling / corrections / Air Charge Temp Multiplier. Also ignition corrections located at > Run-Mode ignition / corrections / Air Charge Temp Multiplier. From Memory the clock cluster gets its speed inputs from the gearbox, when setting up traction control you can wire some convertors into the ABS sensors so that the syvecs sees the correct signal for wheel speed, on a MKIV normally two rear and one front since both fronts should be travelling the same speed or if you have enough inputs then both fronts too, I cant remember 100% its been a while Ahh that may just save my bacon Wez. I was wondering about the wheel speed inputs with regards to the ABS. Hope you don't mind me picking your brain for a sec...... The ABS sensors are for the ABS, obviously, they connect to the ECU but I believe they also have their own ABS ecu? Would I be correct in assuming that if I used 3 sensors in the Syvecs for the wheel speed, this wouldn't effect how the ABS operated and performed? Just thinking of wet/snow braking. I'm at the point now where I've ran out of inputs and I'm about to ditch my oil temperature sensor to make way for the traction control switch. If I could ditch one of the front wheel speed sensors, I could use that input for the oil temperature and then use the remaining input for the TC switch. I emailed Ryan asking about it but I know he's a busy guy. It's often hard to get a response. Thanks Quote Link to comment Share on other sites More sharing options...
Scott Posted March 9, 2015 Author Share Posted March 9, 2015 I have just checked an old calibration and I am showing four speed sensors wired in. I have 4 wired in at the moment, I also have another calibration that Ryan copied over that only uses 2 though. One front and one rear lol. Quote Link to comment Share on other sites More sharing options...
Wez Posted March 9, 2015 Share Posted March 9, 2015 It shouldnt affect the ABS ECU or operation as you should simply be tapping into the signal. Like I said its been a while since I played with it and I know the traction control has evolved since testing the first Syvecs on my MKIV, its quite possible that it only requires two, in its most basic operation you just need to know the speed difference from front to rear to work out if the rear is spinning, obviously knowing what each wheel is doing would allow for finer control. If you have four wired in can you not just assign them in the calibration software under IO / inputs / wheel speed etc. Again mine is old but my two fronts are configured as thermistor and the rears are 5v, this can be found under sensors / speed / input config. Do you have any signal converters wired in like the ones Chris talks about here :- http://www.mkivsupra.net/vbb/showthread.php?316889-Traction-Control-and-ABS-analogue-to-digital-converters Quote Link to comment Share on other sites More sharing options...
Scott Posted March 9, 2015 Author Share Posted March 9, 2015 It shouldnt affect the ABS ECU or operation as you should simply be tapping into the signal. Like I said its been a while since I played with it and I know the traction control has evolved since testing the first Syvecs on my MKIV, its quite possible that it only requires two, in its most basic operation you just need to know the speed difference from front to rear to work out if the rear is spinning, obviously knowing what each wheel is doing would allow for finer control. If you have four wired in can you not just assign them in the calibration software under IO / inputs / wheel speed etc. Again mine is old but my two fronts are configured as thermistor and the rears are 5v, this can be found under sensors / speed / input config. Do you have any signal converters wired in like the ones Chris talks about here :- http://www.mkivsupra.net/vbb/showthread.php?316889-Traction-Control-and-ABS-analogue-to-digital-converters I have them assigned already. I believe they should be working as is, but the TC will need to be mapped. Mine are the same as yours, 2 fronts are thermistor with the 2 rears being 5v and the RADAR (vehicle speed I guess) also 5v. I don't have any converters in mine at all. My setup at the moment is as follows: AN1 - Cam Sensor AN2 - Crank Sensor AN3 - Wheel Speed RL AN4 - Wheel Speed RR AN5 - Vehicle Speed Sensor AN6 - Air Con Switch AN7 - Wheel Speed FL AN8 - Wheel Speed FR AN9 - TPS AN10 - MAP Sensor AN11 - Fuel Pressure AN12 - Oil Pressure AN13 - Coolant Temp AN14 - Oil Temp AN15 - Intake Air Sensor AN16 - Boost Cal Switch TC Switch is all that's missing Quote Link to comment Share on other sites More sharing options...
Wez Posted March 9, 2015 Share Posted March 9, 2015 Here is mine, there are a few differences AN1 - Cam Sensor AN2 - Crank Sensor AN3 - Wheel Speed RL AN4 - Wheel Speed RR AN5 - Lateral G AN6 - Wheel Speed FR AN7 - ALS Switch AN8 - Wheel Speed FL AN9 - TPS AN10 - MAP Sensor AN11 - Traction Control Switch AN12 - Calibration Switch AN13 - Coolant Temp AN14 - Air Charge Temp AN15 - Launch Control Switch AN16 - Pit Limit Quote Link to comment Share on other sites More sharing options...
Scott Posted March 9, 2015 Author Share Posted March 9, 2015 (edited) Here is mine, there are a few differences AN1 - Cam Sensor AN2 - Crank Sensor AN3 - Wheel Speed RL AN4 - Wheel Speed RR AN5 - Lateral G AN6 - Wheel Speed FR AN7 - ALS Switch AN8 - Wheel Speed FL AN9 - TPS AN10 - MAP Sensor AN11 - Traction Control Switch AN12 - Calibration Switch AN13 - Coolant Temp AN14 - Air Charge Temp AN15 - Launch Control Switch AN16 - Pit Limit Do you know where the ECU is getting the vehicle speed from in your setup Wez? Just wondering if I could use the vehicle speed sensor AN5 for a switch. I'm guessing it's probably the wheel speed, but no idea how to configure that. Does your vehicle speed setup show "Radar" after the thermostor and 5v inputs for the wheel speeds? Edit: Funnily enough, in "Vehicle speed select" mine says "AVG COND FRONT" rather than "RADAR". Maybe it was deliberately setup this way after all. Edited March 9, 2015 by Scott (see edit history) Quote Link to comment Share on other sites More sharing options...
Wez Posted March 9, 2015 Share Posted March 9, 2015 Mine is using AVG FRONT for vehicle speed Driven wheel speed select on mine is AVG REAR Quote Link to comment Share on other sites More sharing options...
Scott Posted March 9, 2015 Author Share Posted March 9, 2015 Hmm that's interesting then. With regards to your ALS switch. Do you think I could use the TC switch in the same way that you have with it? I ask as I notice from the guide that the cal switch input normally connects to an AR3 pin, whereas the vehicle speed one is an AU1 pin. Just wondering if it can be configured to work with the switch just the same. Quote Link to comment Share on other sites More sharing options...
Scott Posted March 9, 2015 Author Share Posted March 9, 2015 Lee has just said that he sometimes only uses 2 wheel speed sensors (one front and one rear) in order to free up a couple of inputs. With that in mind, it looks like I may be sorted Quote Link to comment Share on other sites More sharing options...
Wez Posted March 9, 2015 Share Posted March 9, 2015 Some info on pin usage from the Syvecs forum, it states they can be used to measure 0-5v input which is what you need for a traction calibration switch, are you planning to wire up a multi-position switch like a cal switch? AB pins are Analogue Bipolar which means they can be used to measure voltages in the range 0-5V and -5V to +5V. Additionally they can detect speed signals with programmable trigger thresholds. There are four such pins : AB1 is also known as AN01 AB2 is also known as AN02 AB3 is also known as AN03 AB4 is also known as AN04 AU pins are Analogue Unipolar which means they can be used to measure voltages in the range 0-5V and have an optional pull up resistor of 3k for temperature measurements. Additionally they can detect speed signals with fixed trigger thresholds of 1.25V and 3.75V. There are four such pins : AU1 is also known as AN05 AU2 is also known as AN06 AU3 is also known as AN07 AU4 is also known as AN08 AV pins are Analogue Voltage which means they can be used to measure voltages in the range 0-5V but they cannot be used for speed measurements and they have no pull up resistors. There are four such pins : AV1 is also known as AN09 AV2 is also known as AN10 AV3 is also known as AN11 AV4 is also known as AN12 AR pins are Analogue Resistance which means they can be used to measure temperatures and so feature a permanently enabled 3k pull up resistor but they cannot be used for speed measurements. There are four such pins : AR1 is also known as AN13 AR2 is also known as AN14 AR3 is also known as AN15 AR4 is also known as AN16 NB: If the source impedance of a sensor is significantly lower than 3k then it can overpower the 3k pull up and AR inputs can be used as a 0-5V input. Quote Link to comment Share on other sites More sharing options...
Wez Posted March 9, 2015 Share Posted March 9, 2015 Lee has just said that he sometimes only uses 2 wheel speed sensors (one front and one rear) in order to free up a couple of inputs. With that in mind, it looks like I may be sorted Makes sense EDIT: would also explain the cal you have with only two assigned Quote Link to comment Share on other sites More sharing options...
Scott Posted March 9, 2015 Author Share Posted March 9, 2015 From what you have posted above Wez, would you say that I could wire in the TC switch (it's a cal switch like you thought) into AN08? I take it I can just cut the wire that's already in there and solder it on with the ground going to the same one as the current Cal switch? Makes sense EDIT: would also explain the cal you have with only two assigned It explains it, definitely.... but it's not for my car. It was just the map Ryan used to set some default parameters so that he knew where he was starting from when sorting out my fuelling Thanks for your help with this Quote Link to comment Share on other sites More sharing options...
Wez Posted March 9, 2015 Share Posted March 9, 2015 Yes AU inputs can be used for a 0-5v CAL / TRC input. Your vehicle speed select is currently AVG COND FRONT, I suspect this would need changing to the one remaining front speed sensor. Quote Link to comment Share on other sites More sharing options...
Scott Posted March 9, 2015 Author Share Posted March 9, 2015 Yes AU inputs can be used for a 0-5v CAL / TRC input. Your vehicle speed select is currently AVG COND FRONT, I suspect this would need changing to the one remaining front speed sensor. Yip, I'll be changing that to the gearbox speed sensor. It's either that or i can leave it at AVG front which seems to be the recommendation from the setup guide that Ryan did and use the vehicle speed sensor for the switch. Having re-listened to the traction control vid it appears I do indeed need the signal converters. Any idea where these things wire in? Quote Link to comment Share on other sites More sharing options...
Scott Posted March 9, 2015 Author Share Posted March 9, 2015 Do you think this would work? http://www.jbperf.com/dual_VR/v2_1.html Quote Link to comment Share on other sites More sharing options...
Wez Posted March 9, 2015 Share Posted March 9, 2015 I would go with two front sensors and use the AVG COND FRONT for vehicle speed and use AN5 for the switch. Are you switches two or three wire? I have old three wire ones which use GND, 5V REF and a white output signal wire for the ECU. My install deff has some signal converters, they look like orange relays and are wired between the Syvecs and ABS sensor, Chris or Ryan would be best bet on this. Quote Link to comment Share on other sites More sharing options...
Wez Posted March 9, 2015 Share Posted March 9, 2015 Do you think this would work? http://www.jbperf.com/dual_VR/v2_1.html Apparently yes but if you look here there is a comment from Ryan detailing the Siemens relay type unit and how to setup in sCal, this is what I have installed on mine http://www.syvecs.co.uk/forum/viewtopic.php?f=6&t=553 Quote Link to comment Share on other sites More sharing options...
Scott Posted March 10, 2015 Author Share Posted March 10, 2015 I would go with two front sensors and use the AVG COND FRONT for vehicle speed and use AN5 for the switch. Are you switches two or three wire? I have old three wire ones which use GND, 5V REF and a white output signal wire for the ECU. My install deff has some signal converters, they look like orange relays and are wired between the Syvecs and ABS sensor, Chris or Ryan would be best bet on this. Apparently yes but if you look here there is a comment from Ryan detailing the Siemens relay type unit and how to setup in sCal, this is what I have installed on mine http://www.syvecs.co.uk/forum/viewtopic.php?f=6&t=553 Just before I went to bed I went on ebay and bought a couple of them, just on the off chance that I needed them. I'm going to go down the exact route that you suggested. The switches I have are 2 wire. Out of curiosity, do you know where your converters are wired in? Is it on the fields harness or is it before that? Just wondering whether to butcher the harness on the syvecs or whether to further butcher the stock 6spd harness lol. Quote Link to comment Share on other sites More sharing options...
Wez Posted March 10, 2015 Share Posted March 10, 2015 From memory mine are wired in behind the stereo near the ABS ecu. Quote Link to comment Share on other sites More sharing options...
Scott Posted March 10, 2015 Author Share Posted March 10, 2015 From memory mine are wired in behind the stereo near the ABS ecu. Makes sense. Keeps them clear of the footwell. Thanks again Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted March 10, 2015 Share Posted March 10, 2015 I would use screened cable from the ABS sensor tap point to the analogue to digital converters, and from the A to D converters to the Syvecs. You might be interested in this thread I made a while back if you haven't already seen it. http://www.mkivsupra.net/vbb/showthread.php?316889-Traction-Control-and-ABS-analogue-to-digital-converters&highlight=analogue+digital Quote Link to comment Share on other sites More sharing options...
Wez Posted March 10, 2015 Share Posted March 10, 2015 I already linked your thread in post #6 of this thread as I recalled you knocking up some converters Quote Link to comment Share on other sites More sharing options...
