Syvecs S6GP question
ManwithSupra
Just a quick question, when I removed my V160 I undid two connections.
One was the reverse switch the other was what I can only imagine was a Speed sensor.
Does anyone know if this speed sensor is used on when you have a Syvecs ECU?
I have been trying to find a wiring schematic for a manual Supra but cant find anything.
I did try and get hold of Ryan but I believe he is in the air at the moment on his way to Dubai.
It's used for the speedo and depends how the syvecs is set up
Usually it uses the same sensor for speed but can use the abs sensors if you have Trac control setup
Hi Lee,
Cheers for that, I do have Trac control, so can I use the abs sensors instead for speed as my new gearbox does not have a speed sensor.
Edited by ManwithSupra (see edit history)
