MKIV Clutches
SupraTT
I can supply RPS clutches from the USA which is apparently the exact same clutch as TRD sells and wacks a big price tag on. Price for the stage 2 clutch is £411 + UK delivery and VAT and takes about a week to get roughly. This uses a std clutch disc and uprated pressure plate. I use this in my modded Supra and it works a treat, I've sold quite a few recently and all are happy with them, they drive like a standard clutch as well apart from a slight increase in pedal weight.
Give us a shout if you need one or need anymore info
Cheers
Paul
Quote: from SupraTT on 7:07 pm on Feb. 16, 2002[br]Simple one this time folks......
Wheres the best and cheapest place to get a clutch for a MKIV J-Spec TT from ? Nothing over the top but no crap things either, and any prices / contact numbers would be excellentay too ! ;o)
Cheers
Michael
If you need one supplying and fitting I can easily sort that out. Stock ones are great if you haven't any wild mods.
I can turn it round within the day.
Quote: from Paul Whiffin on 8:12 pm on Feb. 16, 2002[br]I can supply RPS clutches from the USA which is apparently the exact same clutch as TRD sells and wacks a big price tag on. Price for the stage 2 clutch is £411 + UK delivery and VAT and takes about a week to get roughly. This uses a std clutch disc and uprated pressure plate. I use this in my modded Supra and it works a treat, I've sold quite a few recently and all are happy with them, they drive like a standard clutch as well apart from a slight increase in pedal weight.
Cheers
Paul
Is it a smooth power transition or is it a bit snappier than stock? I've heard the HKS ones are a bit brutal...which is somthing I'm not looking for.
Cheers
Quote: from SupraTT on 6:06 pm on Feb. 17, 2002[br]I take it that you didnt need to replace the flywheel then ?
I heard that this "has" to be done as well but wasnt convinced....
Arent there any import places in the UK that can supply at a decent price ?
It is definitely NOT essential to replace the flywheel. It will only need attention / renewal if the clutch has badly scored it due to not being changed before the rivets mark the flywheels friction surface.
RPS, Centreforce, etc recommend that the flywheel is faced off when the clutch is being changed.
The RPS clutch is not grabby at all, it uses a std plate so it drives like a std clutch, just a bit heavier. They also do a carbon 6 puck plate for the big power Supra's. Stage 2 clutch is more than up to the job of BPU++.
