Tommyd16 Posted March 5, 2015 Share Posted March 5, 2015 Would there be an issue running a divided turbo with an open manifold? I'm only aiming for 550hp. I've ended up with a divided turbo (listed incorrectly) and undivided mani Quote Link to comment Share on other sites More sharing options...
mellonman Posted March 6, 2015 Share Posted March 6, 2015 There is an issue with running the combination that way around , where the manifold is open the gases would have to be seperated by the turbo housing which over time with the intence heat blasts away the turbine housing divide . but you can run a divided manifold on an open turbine housing without issue . Quote Link to comment Share on other sites More sharing options...
Phlukey Posted March 6, 2015 Share Posted March 6, 2015 You run with this setup if you're going to install a QSV. Quote Link to comment Share on other sites More sharing options...
T14PPA Posted March 6, 2015 Share Posted March 6, 2015 Im in the same position mate. Dont know what to do either as everyone says something different Quote Link to comment Share on other sites More sharing options...
mellonman Posted March 6, 2015 Share Posted March 6, 2015 http://www.ebay.co.uk/itm/Exhaust-Manifold-Toyota-Supra-Mk4-2JZ-Gte-T4-Rear-Croll-Flange-/351281549669?pt=LH_DefaultDomain_3&hash=item51ca031165#ht_2746wt_1190 Quote Link to comment Share on other sites More sharing options...
T14PPA Posted March 6, 2015 Share Posted March 6, 2015 http://www.ebay.co.uk/itm/Exhaust-Manifold-Toyota-Supra-Mk4-2JZ-Gte-T4-Rear-Croll-Flange-/351281549669?pt=LH_DefaultDomain_3&hash=item51ca031165#ht_2746wt_1190 Thanks might might buy that Quote Link to comment Share on other sites More sharing options...
gavin.starr Posted March 6, 2015 Share Posted March 6, 2015 That makes 3 in the same position then Quote Link to comment Share on other sites More sharing options...
T14PPA Posted March 7, 2015 Share Posted March 7, 2015 Loool Quote Link to comment Share on other sites More sharing options...
Wez Posted March 7, 2015 Share Posted March 7, 2015 Would there be an issue running a divided turbo with an open manifold? I'm only aiming for 550hp. I've ended up with a divided turbo (listed incorrectly) and undivided mani Yes, I ran this setup at that power level and the divider on the turbo housing cracked, I ended up purchasing an open / undivided turbo housing. If you still persist with this setup make sure you use a none divided gasket. The other way round is fine Quote Link to comment Share on other sites More sharing options...
Tommyd16 Posted March 8, 2015 Author Share Posted March 8, 2015 How long did it take to crack? Quote Link to comment Share on other sites More sharing options...
Wez Posted March 8, 2015 Share Posted March 8, 2015 How long did it take to crack? No idea sorry. Quote Link to comment Share on other sites More sharing options...
mellonman Posted March 8, 2015 Share Posted March 8, 2015 How long did it take to crack? Nice to know your thinking of building a ticking time bomb lol Quote Link to comment Share on other sites More sharing options...
Tommyd16 Posted March 8, 2015 Author Share Posted March 8, 2015 Ordering new parts right now lol Quote Link to comment Share on other sites More sharing options...
Supradk Posted March 8, 2015 Share Posted March 8, 2015 You have to delete your inbox mate. Can't replay Quote Link to comment Share on other sites More sharing options...
