Divided turbo with undivided manifold?
Tommyd16
There is an issue with running the combination that way around , where the manifold is open the gases would have to be seperated by the turbo housing which over time with the intence heat blasts away the turbine housing divide .
but you can run a divided manifold on an open turbine housing without issue .
Would there be an issue running a divided turbo with an open manifold? I'm only aiming for 550hp. I've ended up with a divided turbo (listed incorrectly) and undivided mani
Yes, I ran this setup at that power level and the divider on the turbo housing cracked, I ended up purchasing an open / undivided turbo housing.
If you still persist with this setup make sure you use a none divided gasket.
The other way round is fine :D
