JDukesy Posted March 5, 2015 Share Posted March 5, 2015 (edited) Hi everyone, Bit of an issue which I'm looking for some advice on. I have done a search and lots of information but nothing that quite matches the problem I'm having. So I have just had my car serviced including full set of new plugs (NGK BKR5EYA-11). However got in the car this morning started fine all seemed normal. Drove off casually then first time putting my foot in it a bit it revved to about 3k and then just hesitates and misfired,. Then on idle it began to pop and I could feel vibration. If I raised the revs to about 1k it was fine and car behaves normally between 1-3k rpm. I am pretty clueless when it comes to these kind of things so any help or advice would be much appreciated. Thanks! Edited March 6, 2015 by JDukesy (see edit history) Quote Link to comment Share on other sites More sharing options...
Rummy Posted March 5, 2015 Share Posted March 5, 2015 Sounds like the spark is breaking down under load. I would check the Dizzy cap Quote Link to comment Share on other sites More sharing options...
Nic Posted March 5, 2015 Share Posted March 5, 2015 (edited) The most obvious cause of a misfire at this time of year would be water/moisture in the electrics, blow out the plug wells, distributor cap and leads with compressed air and give all a spray with WD40, also check the HT leads are properly fitted. Edited March 5, 2015 by Nic (see edit history) Quote Link to comment Share on other sites More sharing options...
JDukesy Posted March 5, 2015 Author Share Posted March 5, 2015 Thank you both. I have tomorrow off so shall have a poke around and see what's what! Quote Link to comment Share on other sites More sharing options...
JDukesy Posted March 6, 2015 Author Share Posted March 6, 2015 Here is a video of idle after about 2 minutes. Popping was probably the wrong word, more like spluttering. Thoughts? I had a look and it looks like someone at the garage has spilt oil on the camcover when filling it up, is it possible that there could just be some oil in the spark plug wells causing this? https://vimeo.com/121442615 Quote Link to comment Share on other sites More sharing options...
ballsdeep Posted March 6, 2015 Share Posted March 6, 2015 As Nic said could be water or oil in the spark plug chambers, pull the leads off and have a look, if it's all dry touch all the leads when it's running, one might be arking..? You might get a very slight tingle if it is lol Iv Had this problem before once with water getting in from the Allen key bung in the head and a split ignition lead! Also check the king lead (coil to distributor) Quote Link to comment Share on other sites More sharing options...
ballsdeep Posted March 6, 2015 Share Posted March 6, 2015 (edited) Double post Edited March 6, 2015 by ballsdeep (see edit history) Quote Link to comment Share on other sites More sharing options...
JDukesy Posted March 10, 2015 Author Share Posted March 10, 2015 Problem solved. Thanks for all the help. One further question, I am thinking I might just replace distributor cap, rotor arm and ignition leads while I am refreshing things anyway. Where is the best place to get all of this stuff, any recommendations? Thanks, Quote Link to comment Share on other sites More sharing options...
Mike2JZ Posted March 10, 2015 Share Posted March 10, 2015 Problem solved. Thanks for all the help. One further question, I am thinking I might just replace distributor cap, rotor arm and ignition leads while I am refreshing things anyway. Where is the best place to get all of this stuff, any recommendations? Thanks, When I went to refresh all that on my N/A I found loads of good deals + quick international shipping from RocAuto Quote Link to comment Share on other sites More sharing options...
JDukesy Posted March 10, 2015 Author Share Posted March 10, 2015 Thanks, I shall give them a try! Quote Link to comment Share on other sites More sharing options...
Nic Posted March 10, 2015 Share Posted March 10, 2015 Problem solved. Thanks for all the help. What was it? One further question, I am thinking I might just replace distributor cap, rotor arm and ignition leads while I am refreshing things anyway. Where is the best place to get all of this stuff, any recommendations? Replace with either genuine OEM Toyota parts or you may find it cheaper to source from Denso (who supply the OEM parts to Toyota) if they are listed here http://densoautoparts.com/find-my-part/vehicle-selection Quote Link to comment Share on other sites More sharing options...
Rich.2211 Posted March 10, 2015 Share Posted March 10, 2015 TCB parts are worth a try also. They are one of the cheapest places I've found for OEM parts and certainly have the best customer service. Quote Link to comment Share on other sites More sharing options...
