Bulb types - UK/Facelift
Ric
Hi Guys,
I had UK glass lights in my supra before and im switching to facelifts.
My question is about bulbs - I've searched and used this thread - http://www.mkivsupra.net/vbb/showthread.php?215323-What-Bulb-Guide-Pre-Facelift-and-Facelift
However the information in there contradicts what I'm seeing.
I had a 9006/HB4 HID kit fitted to my UK lights, it fitted and worked fine.
This bulb will nowhere near fit into my Facelift lights (the light base is too thick for the hole.
I have a HB3/9005 HI beam bulb here, and that fits into the hole for both HI beam and LO beam, but the thread above says different and that 9006 should fit?!
To cover my question completely.
Which bulb is required?
HI - 9005/HB3
LO - ?
Fog - H3
Side repeater - 501?
Facelift indicator - 7440?
Facelift Sidelight - 501
If the thread above is wrong, can it be edited? it's in the FAQ section?
Thanks
if that FAQ is wrong then there is no hope lol
Yes it is wrong :)
This other FAQ post explains it correctly http://www.mkivsupra.net/vbb/showthread.php?142251-Which-headlight-bulbs-for-JSpec-and-UK-Spec
These are the bulbs you will need for each type of headlight.
UK spec
Low 9006/HB4
High 9005/HB3
J-spec
Low 9005/HB3
High 9005/HB3
Yes it is wrong :)
UK spec
Low 9006/HB4
High 9005/HB3
J-spec
Low 9005/HB3
High 9005/HB3
Cheers nic, hopefully i have the right kit now.
I tried to search for other threads, i never seem to get good results just loads of pointless threads which mentioned facelift lol, thousands. i usually get much better results searching straight from google, which links here.
