drew 007 Posted February 27, 2015 Share Posted February 27, 2015 Hi Guys, I'm needing to change the side indicator bulb on my front bumper.(Facelift supra), But one I'm not sure how to get the repeater off the side of the front bumper, And two, I'm not sure what bulb to get. Im needing this sorted asap as I've got an mot tomorrow and only just seen it. Ive tried just pulling the indicator lense but I'm not convinced thats how you get to the bulb? Ive had a search but can't find any info on how to replace the bulbs. Any info will be really appreciated. Kind regards. Quote Link to comment Share on other sites More sharing options...
1_Tidy_1 Posted February 27, 2015 Share Posted February 27, 2015 Na man they are bolted from the inside. Just stick your hand up from the bodem and you should be able to see the nuts be a 2 second jobbie pulling them out Quote Link to comment Share on other sites More sharing options...
1_Tidy_1 Posted February 27, 2015 Share Posted February 27, 2015 Ow if you just want the bulb out you need to twist the center from the back qnd it will come strait out, slide the new bulb in and presto doneski Quote Link to comment Share on other sites More sharing options...
drew 007 Posted February 27, 2015 Author Share Posted February 27, 2015 (edited) Thats fantastic, thanks for the heads up. so you need to get behind the shi* pans to get to the nuts/bolts. Edited February 27, 2015 by drew 007 (see edit history) Quote Link to comment Share on other sites More sharing options...
drew 007 Posted February 27, 2015 Author Share Posted February 27, 2015 As for just sticking my hand up... There is no chance. Been trying to remove the shi* pan but still can't get to the dam thing. I'm going to try and take the air filter out and see if I can get in that way. As it does look and feel that they just twist and pull out!! Quote Link to comment Share on other sites More sharing options...
ScottC Posted February 27, 2015 Share Posted February 27, 2015 Remove head light and voila! Quote Link to comment Share on other sites More sharing options...
drew 007 Posted February 27, 2015 Author Share Posted February 27, 2015 Top man. Really appreciated. Quote Link to comment Share on other sites More sharing options...
