GreekSupra Posted February 25, 2015 Share Posted February 25, 2015 Hello guys I removed my Diff to change the mounts, can you please someone let me know what kind of Diff is Removed from Supra NA Auto. I also have purchased this Solid Mount Bushes but the 2 Subframe Diff holes are bigger and the mounts getting through the Hole. Do I need to have the OEM Rubber Diff mounts connect with those Solid mounts to work? Thanks you guys Quote Link to comment Share on other sites More sharing options...
Grasmt Posted February 25, 2015 Share Posted February 25, 2015 Pass on what diff you have there but the diff mounts you have there fit inside the oem rubber bushes, they are not weld or push in parts Quote Link to comment Share on other sites More sharing options...
David P Posted February 25, 2015 Share Posted February 25, 2015 It will be a 4.083, could be either stock open or Torsen. Post up a pic of the insides and you'll get your answer. Quote Link to comment Share on other sites More sharing options...
GreekSupra Posted February 25, 2015 Author Share Posted February 25, 2015 So if I understood well, I need also to buy the OEM Rubber Diff Bushes , right? to make them fit. This is another photo if this helps Quote Link to comment Share on other sites More sharing options...
Grasmt Posted February 25, 2015 Share Posted February 25, 2015 Yes you need the oem rubber bushes too, i have them on mine so ill see if i can get a pic for you Quote Link to comment Share on other sites More sharing options...
GreekSupra Posted February 25, 2015 Author Share Posted February 25, 2015 Thanks mate. Do you know where can I get this mounts New? Also I am looking for the Subframe Mounts Bushings as well? Anyone Quote Link to comment Share on other sites More sharing options...
Grasmt Posted February 25, 2015 Share Posted February 25, 2015 Go direct to toyota, check http://toyodiy.com for part numbers Quote Link to comment Share on other sites More sharing options...
bignum Posted February 25, 2015 Share Posted February 25, 2015 So if I understood well, I need also to buy the OEM Rubber Diff Bushes , right? to make them fit. This is another photo if this helps [ATTACH=CONFIG]197903[/ATTACH] Err, where are the insides gone lol, need to see that to tell what diff, probably an open though. Quote Link to comment Share on other sites More sharing options...
GreekSupra Posted February 25, 2015 Author Share Posted February 25, 2015 Is this the small or big case? I am thinking for a Trd lsd Quote Link to comment Share on other sites More sharing options...
David P Posted February 25, 2015 Share Posted February 25, 2015 That's a proper "open" diff. Quote Link to comment Share on other sites More sharing options...
