paul21uk Posted February 24, 2015 Share Posted February 24, 2015 Does anyone know if there is some kind of relay on the ignition side of things as struggling to diagnose my no start situation all fuses checked crank sensor changed cps's changed and still nothing Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted February 24, 2015 Share Posted February 24, 2015 Is there definitely no spark? Or are you assuming? If you are not sure WHY it won't start spray Easy Start into the throttle body whilst cranking and see if it fires up briefly. If it does it's not a no spark issue. If it doesn't it almost certainly is. Then I can assist further. Quote Link to comment Share on other sites More sharing options...
paul21uk Posted February 25, 2015 Author Share Posted February 25, 2015 Yes mate positive its a no spark issue I haven't tried the throttle body trick as yet but I shall give it a go this weekend just to be sure Quote Link to comment Share on other sites More sharing options...
