pedrosixfour Posted February 23, 2015 Share Posted February 23, 2015 Hey folks. Can anyone tell me what the physical dimensions of the shims used in a small case differential are, outside diameter and inside diameter is really all I'm after so I can see if I have anything in stock that would match them. I'll be completing an LSD swap from a Torsen unit to a new Cusco unit using the same casing & gear ratio in the near future. I swapped out the gear ratio before and chanced the result to luck when it came to gear contact and bearing preloads. It turned out to be a complete success as it happens and I've had no trouble with the differential since. But with the new Cusco item I'd prefer to do the job properly & overhaul the diff while I'm at it so new bearings, seals, O-rings, shims & crush tube are all needed. Thing is, I've literally hundreds of shims at my (unofficial) disposal in the workshop, some possibly even with the right inner & outer diameters, and it would make the diff overhaul that much simpler & quicker if I could gather up a number of these shims in various thicknesses and use them to determine what proper single thickness shims would be needed from Toyota to complete the overhaul. I won't get a chance to pull the diff from the car and strip it for a while yet and I'd like to have some of the groundwork done in the meantime. Thanks. Quote Link to comment Share on other sites More sharing options...
pedrosixfour Posted March 1, 2015 Author Share Posted March 1, 2015 Nobody have a few of these hanging on a nail somewhere?? Quote Link to comment Share on other sites More sharing options...
