Bailey's Silver Bullet Auto
Lee P
  • Replies 540
Posted Images
Thanks guys, happy with the numbers!
Unfortunately we have a gearbox issue, lost 3rd gear on the dyno and then reverse gear. I also believe it lost all gears at one stage. Hopefully its just a torque converter fault. If not it could be something more serious like the gearbox itself. Lee's going to look into it today.
2412 lbft is that what gave the gearbox/converter fault away?
Lee must have been pouring SRD glitter in the Box :D
Lol... That's how the hub dyno works. You divide the torque figure by the ratio
It was 550ftlbs but we had a problem with the TC or gearbox hence the slipping
Only one thing for it unfortunately, you'll just have to convert to six speed.....
Even with the issues you still gained about 700rpm for full torque , shame that there is a problem though . You can have a stock TC rebuilt in the uk I had mine done google JPAT , the slipping if its the lock up clutch can be replaced but it all costs more then you could pick up a spare TC for but I was looking into other things.
Best of luck with it though
The built box $#@! itself?
Not quite it's not totally gone - looks like the clutches are ok no bad burning smell. Might just be seals but won't know full extent until box is stripped and check obvious bits. Will take Lees advice on whether it needs further strengthening like SRD spec boxes.
Id be expecting a warranty replacement tbh......
Still shudnt $#@! itself at that power and torque for what they claim its capable of. Fit for purpose springs to mind
Not sure what the actual figure they quote it at is, although I do remember briefly seeing that the BL box doesnt like being used in manual mode. Which obviously we would have been doing with the syvecs flappy paddle conversion.
