msupra1 Posted February 22, 2015 Share Posted February 22, 2015 (edited) I removed my active front lip assembly, I also (cut) the socket that plugs into it (just tapped it off with electrical tape). I have now sold the active lip. The dashboard button has also been removed. I did some searching and seems like its pretty standard for the warning light to stay on once removed. Just wondering if there is a particular fuse I can pull, or I have read about there being an ECU for the active front lip located somewhere behind the dash? and if that's unplugged that will solve the issue? Where exactly would it be and how does it look? I just want to get rid of the (!) WARNING light. cheers Edited February 22, 2015 by msupra1 (see edit history) Quote Link to comment Share on other sites More sharing options...
Slam Posted February 22, 2015 Share Posted February 22, 2015 The fuse is in the drivers side foot well right panel. Its a big fuse. Which warning light is on. Quote Link to comment Share on other sites More sharing options...
1_Tidy_1 Posted February 22, 2015 Share Posted February 22, 2015 Or just pull the dash pannel of ( the one from the stereo and disconnect aka just unplug the active spoiler ecu which sits right down the bodem behind that panel, and that will makr your light go off done it before as well so Quote Link to comment Share on other sites More sharing options...
Marty Posted February 22, 2015 Share Posted February 22, 2015 Or just pull the dash panel off (the one from the stereo and disconnect aka just unplug the active spoiler ecu which sits right down the bottom behind that panel, and that will make your light go off done it before as well so The ecu is your problem. Its directly behind the stereo area with a few other ecu's (aerial one) etc. Quote Link to comment Share on other sites More sharing options...
msupra1 Posted February 22, 2015 Author Share Posted February 22, 2015 I guess I'll be pulling to stereo and try and get to it, how does it look? Quote Link to comment Share on other sites More sharing options...
jamesmark Posted February 22, 2015 Share Posted February 22, 2015 I guess I'll be pulling to stereo and try and get to it, how does it look? As said take the dash panel off that hold the stereo, and the active spoiler ECU is right in front of you. Memory serves there are 2 boxes and the active ECU sits on the top. Very easy to get to and take out. Quote Link to comment Share on other sites More sharing options...
