gizzmo ibc-r help needed
Guest pgill40
Guest pgill40
Ok. I have just installed a gizzmo ibc-r on my supra na-t.
It's all plumbed in correctly but I have a problem.
I'm not seeing any boost registering on the real time boost display.
It's connected from the same vacuum source as my greddy emanage and boost gauge so I know it's a reliable source.
I've gone through the setup over and over but it's not recognising any boost even on wot. My boost gauge however is working fine.
Do I have a faulty unit?
Also, it has an rpm dependent boost function if I want to use it.
Does anyone know if the rpm signal wire needs to be connected for it to work properly even if I don't want to use it?
Help on this would be much appreciated.
