Who wants to have a laugh?????? At my MOT failure
Carzymike1987
Sorry to hear your supe failed,
As far as I'm aware all UK spec cars came with fog lights fitted as standard where as they are or were not a requirement in Japan so they weren't fitted
So if your car is an import and never had the fog light mod done it would be safe to assume you don't have one
But judging from the MOT certificate, it does have one and a switch to go with it, if it has had the tail lights nodded with the fog light the best thing to start with is the wiring.
Check in the boot near the light loom and see if it has been cut into at all, if it has it probably has had the fog light mod done just check all of the wires coming from the loom to make sure they are correctly connected
I would also check the switch in the dash, pull it out and make sure they are all connected.
If it is a UK spec car I couldn't really tell you what to look for as mine is a J-Spec so I had to do the fog light mod my self so I'm just going on my knowledge of what I had to do to, to get it working
There is a thread on here in regards how to do the fog light mod if you need it, sorry I don't have the link
Hope this helps you in some way
And good luck with sorting out your supe
All cars after 1980 require a fog light.
Pics of the number plates? And the rest of the failure?
Cheers everyone I can sort number plates so that's all good,
Tbh that is it, well the only thing that I was unsure of, others are just horn not secure, new pads front and rear, and apparently my drivers seat is "loose"
The cars an NA so it's an import, all UK spec cars were Twin Turbo
Seems like there being overly picky. The fog light fair enough but serious "horn insecure", "seat loose" either your car is falling apart and loose everywhere which I doubt. Or they are just nobs
Ha ha cheers jason, the horn and seat issue sorted, just fog light issue needs sorting I'm sure it should have had the upgrade, going to look at all the wiring looms etc, if not I will just add one,
What did you to remedy the seat issue? Was it not bolted down properly or was there forward and backwards play in the seat? (I've noticed that in a couple of Supras with the stock seats).
[ATTACH=CONFIG]197664[/ATTACH]
Fixed your image for you :p To bad to hear your supra failed, having some issues over here aswell to even get it imported from england :(. Hope you pass fast! :D
Cheers and thank you, their not big issues and hope to be back on the road next month,
Hope you get a supra pal best car ever owned miles better than my Bmw M sport,
Working on it! :D
She has issues starting, probably the wiring from age & rust & standing still. Will fix that soon (gonna be installing a start button probably too :p), then going to do the fog light mod, get the wheel allignment done & get it checked, then do another MOT & i should pass too :D
Best of luck to you mate :D
