Master warning triangle and yellow engine light
drift_bear
I decided that since the weather is nice, I would take the car to my work for once. I checked all fluids and they were fine, checked the temps as I was driving and all seemed fine and there was no knocking/banging/smoke...
When I reached the dual carriageway i gave it some boost (1.2bar) and the master triangle and yellow warning light came on for about 2-3seconds then went off and never came back on. I carried on to work but just nursed it to see if it came back on, but it never.
I will need to hook up the syvecs to the computer this weekend, but anyone have any ideas what it could be or what to check?
I thought that was when the stock ecu saw knock , but the syvecs would of picked that up?
There's nothing flashes up on the toucan for knock, will just have to plug the old laptop in
Knock warning light... not sure if it's configured to other warnings. Need to plug your laptop in and take a look.
What would be causing that?
I presume you checked the brake fluid level?;)
:p :p
