JordanC Posted February 18, 2015 Share Posted February 18, 2015 Hello! Could anyone recommend a good car battery for the supra? I've currently got a Yuasa in there but I think the cold weather has killed it because it only seems to hold a charge for about 3 days. I've used a booster pack to start it previously. Went to get in this morning and turned the key just to hear click click click click click Any good batteries anyone can recommend? On an unrelated note, how common is it for the bulbs behind the clock faces in the dash to need replacing? My speedo from 30 to about 80mph is no longer backlit and the rev counter from about 5k - 8k rpm is no longer backlit either! All the other lights (and sections of the RPM/speedo cluster) seem to be working fine, sometimes have to give the temp a little tap with the knuckle to get it to light up, same for the auto shifter light but the other sections are beyond tapping! Quote Link to comment Share on other sites More sharing options...
Rummy Posted February 18, 2015 Share Posted February 18, 2015 Halfrauds HCB005 has always served well. 4 year guarantee too Quote Link to comment Share on other sites More sharing options...
JordanC Posted February 18, 2015 Author Share Posted February 18, 2015 Halfrauds HCB005 has always served well. 4 year guarantee too Been fine over winters too?? I should've mentioned the supra is my daily at the moment so its used in all conditions! Quote Link to comment Share on other sites More sharing options...
j_jza80 Posted February 18, 2015 Share Posted February 18, 2015 On a road car, I would go to Halfords for a Halfords or Bosch battery, just for the convenience of being able to swap a faulty one over. Make sure you can get a trade price though, because the RRP of batteries is expensive. Quote Link to comment Share on other sites More sharing options...
Steve Paine Posted February 18, 2015 Share Posted February 18, 2015 My Halfords HCB005 has fried a cell after 2 1/2 years. Receipt had faded to nothing so I binned it, not expecting any problems with it. Halfords won't change it now without proof of purchase! Quote Link to comment Share on other sites More sharing options...
Wez Posted February 18, 2015 Share Posted February 18, 2015 If you want another Yuasa battery you can get them at AllParts http://www.allpartsautomotive.co.uk/ Quote Link to comment Share on other sites More sharing options...
JordanC Posted February 19, 2015 Author Share Posted February 19, 2015 I can get trade discount from Halfords, a mate used to work there and is still friendly with all the current staff at my local branch, would you go for a new Yuasa or a new Halfords? I'm thinking Halfords just for the guarantee but the Yuasa has been fine until winter. Quote Link to comment Share on other sites More sharing options...
cered Posted February 19, 2015 Share Posted February 19, 2015 Bosch S5 from carparts4less.co.uk, Halfords batteries are good but if you look around Bosch batteries can be had for similar prices... And you don't have to give Halfrauds your money Quote Link to comment Share on other sites More sharing options...
suprasurrey Posted February 19, 2015 Share Posted February 19, 2015 My Halfords HCB005 battery has a dud cell now and is only around 18 months old:badmood:Receipt is unreadable so probably won`t get a replacement. Quote Link to comment Share on other sites More sharing options...
garethr Posted February 19, 2015 Share Posted February 19, 2015 (edited) Last couple I've bought have been Bosch S4. The 005 is about £70 from Euro Car Parts or a few quid cheaper off ebay. If the financial penalty isn't too large, I prefer to buy locally. It's easier to return the battery if it packs up before the guarantee runs out. (I don't know what the Supra battery tray is like, but I have fitted a larger battery - more amp hours - in the Soarer.) Edited February 19, 2015 by garethr (see edit history) Quote Link to comment Share on other sites More sharing options...
Marty Posted February 19, 2015 Share Posted February 19, 2015 I bought a halfords one based on the recommendations on here, HCB005. It wasn't a direct fit ! It was taller than the one i was replacing. Meaning neither the bar that goes over the battery to hold it in place, or the hook that goes from the bar to the battery tray would fit. I had to extend the hooked bar and put a bend the one that goes over the battery Quote Link to comment Share on other sites More sharing options...
JordanC Posted February 19, 2015 Author Share Posted February 19, 2015 I bought a halfords one based on the recommendations on here, HCB005. It wasn't a direct fit ! It was taller than the one i was replacing. Meaning neither the bar that goes over the battery to hold it in place, or the hook that goes from the bar to the battery tray would fit. I had to extend the hooked bar and put a bend the one that goes over the battery Christ I don't even know where my battery clamp etc is, battery is just loose atm which is not good but doesn't seem to move really. I would like a battery that's going to be a direct fit! Quote Link to comment Share on other sites More sharing options...
garethr Posted February 19, 2015 Share Posted February 19, 2015 (edited) Christ I don't even know where my battery clamp etc is, battery is just loose atm which is not good but doesn't seem to move really. I would like a battery that's going to be a direct fit!It's easy to find the battery dimensions online, so you can compare with the current one. For example: Bosch S4 005 Amp Hours: (Ah): 60Ah Cold Cranking Amp: (CCA): 540cca Length: 232mm Width: 173mm Height: 225mm Halfords HCB005 AH Value: 62 Startup Power: 510 Amps Dimension (LxDxH): 232x173x225mm EDIT: Should I mention terminal sizes? EDIT AGAIN: A loose battery should be an MOT failure. http://www.motinfo.gov.uk/htdocs/m4s01000901.htm Edited February 19, 2015 by garethr (see edit history) Quote Link to comment Share on other sites More sharing options...
Alex Posted February 19, 2015 Share Posted February 19, 2015 Varta Silverline is another option. Quote Link to comment Share on other sites More sharing options...
Steve Paine Posted February 19, 2015 Share Posted February 19, 2015 Update on the Halfords issue! I registered a gentle complaint on the website re receipt unable to read etc! They said as it is a Halfords battery the store should be able to ascertain date of sale. They told me to take it back and they would deal with it accordingly. Just went there and they have changed it FOC! Result! Thanks Halfords! Quote Link to comment Share on other sites More sharing options...
JordanC Posted February 19, 2015 Author Share Posted February 19, 2015 It's easy to find the battery dimensions online, so you can compare with the current one. For example: Bosch S4 005 Amp Hours: (Ah): 60Ah Cold Cranking Amp: (CCA): 540cca Length: 232mm Width: 173mm Height: 225mm Halfords HCB005 AH Value: 62 Startup Power: 510 Amps Dimension (LxDxH): 232x173x225mm EDIT: Should I mention terminal sizes? EDIT AGAIN: A loose battery should be an MOT failure. http://www.motinfo.gov.uk/htdocs/m4s01000901.htm Funny you should mention this as when I took her for an MOT in September last year, I had a funny feeling the guy in the garage had just sat in on ramps and opened the doors to give off the impression he'd done something with it. Either that or he didn't know himself!! Quote Link to comment Share on other sites More sharing options...
