120 amp fuse blown, how to replace?
hogmaw
It's the bottom left one in the pic below, in the fuse box under the bonnet next to the battery. It may well be the alternator one as there are no electrics working at all; no speedo, no lights, no electric windows, no dash fan, no indicators...
Thanks for the info :)
Is this the correct replacement? Looks similar but not sure
http://www.ebay.co.uk/itm/171356785825?_trksid=p2060778.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
One or two dimensions not quite right with that particular fuse, I got a spare from Toyota a while ago as there seemed to be nothing else available to fit the moulded receiver in the fusebox the original fuse is made for.
I'll bet you haven't blown it, I thought the same 2 weeks ago, it was my battery that was fooked, but I went down the route of changing that fuse... I got it from Steve Manley at Oxford Toyota for £14 I think.... Only to find out it was the battery... If you can wait until after this weekend I can bring down my battery and fuse to try if you want....
Top marks Bignum, I had to jump start it this morning not having started it for about a month. I had to take a guess with the jump leads as the battery on the donor car wasn't marked black/red... looks like I guessed wrong! I should have looked closer to see if there was a -ve and +ve marked but too late now. The car does start and does drive, but with no electrics. Fuse is deffo blown. I just have to find one now.
When minw blew/cracked (From old age) I could not start and drive the car. I'd check all the other fuses as well before you do anything else.
