supra TT 6 speed conversion questions?
supra_24
Hey guys,
I currently own a 93 Supra MK4 Supra with 5 speed w58 gearbox and stage 3 + clutch.
I plan to swap to a 6 speed gearbox setup very soon, but just wondered in order to do so, what parts will I need to achieve this?
I don't believe I will need the pedal setup, is that correct?
And I'm guessing a stage 1 clutch for the 6 speed Is in order?
Any insight is appreciated ;)
Regards
Ash
I have a list saved on my computer but off the top of my head.
Box with shifter
Gearbox mount
Clutch
flywheel
Slave cylinder
Prop
Diff or diff flange
Drive shafts that go with the diff.
All lines
Not that you want a six speed conversion or anything LOL
As you are 5 speed already you will need:
complete Box
Gearbox mount
Clutch
flywheel
Slave cylinder
part clutch line
Prop
also if you plan on using the proper drivetrain then:
Diff
Drive shafts
everything else is the same like pedals, rev counter, gear surround etc.
i have a car due in friday with a v160 kit and large casing diff ;)
Cheers guys, forgot to mention that mine is a Twin turbo engine GTE, not sure if that makes any difference?
Would my slave need changing if I already have this setup?
Also can you guys tell me where I can get the following parts:
Lines
Slave
Suitable diff with casing
Diff drive shafts
I know I can get a full 6 speed with gear selector and linkage.
I can also get propshaft, clutch, flywheel and gearbox mount from Whifbitz.
Ohhh shots fired. How about I give you my w58 conversion and I will take the v160 ;)
Haha, I'm skint anyway mate unless Keron starts accepting Sexual Payments......:eyebrows:
you seen the light then? :D
6 Speed has always been the plan (at some point) lots to save for first though :)
