johnd-mkiv Posted February 16, 2015 Share Posted February 16, 2015 What oil would you recommend for running in the 2jz? also a recommended oil after, fully built single turbo around 800 horses thanks;) Link to comment Share on other sites More sharing options...
Paul Whiffin Posted February 16, 2015 Share Posted February 16, 2015 Millers running in oil, I keep it in stock here if needed. Link to comment Share on other sites More sharing options...
johnd-mkiv Posted February 17, 2015 Author Share Posted February 17, 2015 Thanks Paul Link to comment Share on other sites More sharing options...
Mk4Gaz Posted February 17, 2015 Share Posted February 17, 2015 20w 50 cheap oil, for the initial start, and bedding the cams etc in Then drop it, and replace with millers 10w 40 running in oil - and a new filter, as Paul suggests. Link to comment Share on other sites More sharing options...
johnd-mkiv Posted February 17, 2015 Author Share Posted February 17, 2015 I can see my dad running his work horse off all this oil:d Link to comment Share on other sites More sharing options...
