j_jza80 Posted February 16, 2015 Share Posted February 16, 2015 Which brake hoses do people use when doing these swap? Are the stock ones okay, or are a custom set with LS400 ends preferable? Are there any locating tabs etc on the end of the stock LS400 hoses? Cheers Quote Link to comment Share on other sites More sharing options...
Shane Posted February 16, 2015 Share Posted February 16, 2015 Which brake hoses do people use when doing these swap? Are the stock ones okay, or are a custom set with LS400 ends preferable? Are there any locating tabs etc on the end of the stock LS400 hoses? Cheers I used a set of HEL JZA80 hoses with mine and yes I am pretty sure the LS400 hoses had locating tabs (hooked shape rods I think) on. I may have the old hose or parts of at home and I can check this evening if home in time. Quote Link to comment Share on other sites More sharing options...
j_jza80 Posted February 16, 2015 Author Share Posted February 16, 2015 If you wouldn't mind, that would be great. I will be going for braided hoses, I might as well make sure they have the correct fittings Quote Link to comment Share on other sites More sharing options...
Shane Posted February 16, 2015 Share Posted February 16, 2015 Hope that helps Quote Link to comment Share on other sites More sharing options...
j_jza80 Posted February 16, 2015 Author Share Posted February 16, 2015 Thanks Quote Link to comment Share on other sites More sharing options...
Shane Posted February 16, 2015 Share Posted February 16, 2015 No worries, here's another from a different angle. If you want one to use as a pattern if you go down the custom route then let me know and I can stick it in the post. Quote Link to comment Share on other sites More sharing options...
