JayJay1374 Posted February 11, 2015 Author Share Posted February 11, 2015 Mine looks exactly like that. And I have mounted it like that. With the engine behind. - - - Updated - - - You should be able to tell if its on the right way By just looking down the line of the belt Jonny, if its on wrong the belt wont line up properly with the tensioner, it will go on but look out of alignment The pulleys a lot wider than the belt so it's hard to tell mate. Quote Link to comment Share on other sites More sharing options...
Scott Posted February 11, 2015 Share Posted February 11, 2015 Mine looks exactly like that. And I have mounted it like that. With the engine behind. - - - Updated - - - The pulleys a lot wider than the belt so it's hard to tell mate. If you have a look at the picture I posted compared to your last pic, it looks as if the side that you have showed was fouling on something engine side. Are you sure that the pulley isn't designed to go on with the damaged face out........? I understand the logo would be on the inside, but what if the etching was on the wrong side? Quote Link to comment Share on other sites More sharing options...
JayJay1374 Posted February 11, 2015 Author Share Posted February 11, 2015 I didn't really take it into consideration as you'd expect the logo to be facing out. I will be going to a bearing shop tomorrow to replace the bearing. Then I will try again. Quote Link to comment Share on other sites More sharing options...
Scott Posted February 11, 2015 Share Posted February 11, 2015 I didn't really take it into consideration as you'd expect the logo to be facing out. I will be going to a bearing shop tomorrow to replace the bearing. Then I will try again. Definitely lol. It just explains it Quote Link to comment Share on other sites More sharing options...
Paul Whiffin Posted February 11, 2015 Share Posted February 11, 2015 You have fitted it around the wrong way, I don't think you can bolt it on around the wrong way unless you space it out somehow? Quote Link to comment Share on other sites More sharing options...
Scott Posted February 11, 2015 Share Posted February 11, 2015 You have fitted it around the wrong way, I don't think you can bolt it on around the wrong way unless you space it out somehow? That's the thing though Paul. It was fitted with the logo out, so the logo must have been on the wrong side. Quote Link to comment Share on other sites More sharing options...
a98pmalcolm Posted February 11, 2015 Share Posted February 11, 2015 All the logos are facing out by the looks of things in the pic.. Its not double sides logos is it? Quote Link to comment Share on other sites More sharing options...
Scott Posted February 12, 2015 Share Posted February 12, 2015 All the logos are facing out by the looks of things in the pic.. Its not double sides logos is it? Are you looking on your phone? Picture showing the damage shows no logo Quote Link to comment Share on other sites More sharing options...
JayJay1374 Posted February 12, 2015 Author Share Posted February 12, 2015 New bearing in. Fitted what I would say is the wrong was around. Working spot on. Annoying really about the fact it's logo is now on the inside. Which was very misleading when fitting. Quote Link to comment Share on other sites More sharing options...
Scott Posted February 12, 2015 Share Posted February 12, 2015 New bearing in. Fitted what I would say is the wrong was around. Working spot on. Annoying really about the fact it's logo is now on the inside. Which was very misleading when fitting. It shouldn't be. It's been a mistake at the etchers. Quote Link to comment Share on other sites More sharing options...
Paul372 Posted February 12, 2015 Share Posted February 12, 2015 I had that same problem with my tensioner pulley I brought from Paul the etching / logo was on the wrong side of the pulley but I figured it out, so the etching / logo is on the back of the pulley Quote Link to comment Share on other sites More sharing options...
Al Massey Posted February 12, 2015 Share Posted February 12, 2015 Maybe a message to Paul to let him know there's a problem, so hopefully others wouldn't have the same problem Quote Link to comment Share on other sites More sharing options...
jsnlvxr Posted March 3, 2015 Share Posted March 3, 2015 I fitted mine today and the etching is on the wrong side too. Tad annoying! Quote Link to comment Share on other sites More sharing options...
Al Massey Posted March 3, 2015 Share Posted March 3, 2015 I fitted mine today and the etching is on the wrong side too. Tad annoying! Have you let Paul know? Quote Link to comment Share on other sites More sharing options...
jsnlvxr Posted March 3, 2015 Share Posted March 3, 2015 Just emailing him to let him know Quote Link to comment Share on other sites More sharing options...
Paul Whiffin Posted March 3, 2015 Share Posted March 3, 2015 Sorry about this, looks like there was a batch with the logo on the wrong side! If you want to send it back I can get it swapped over for you? Quote Link to comment Share on other sites More sharing options...
Paul372 Posted March 3, 2015 Share Posted March 3, 2015 I'm happy with mine it's working great and it doesn't bother me about not being able to see the logo Quote Link to comment Share on other sites More sharing options...
