markssupra Posted February 9, 2015 Share Posted February 9, 2015 Hi all, Does anyone have the pin outs for a J-spec ABS ECU? I have been looking at my own Toyota manual and the ones on here but mine is differerent. I only have 2 plugs, a 26 pin and 16 pin, I only need to find the -Front left and -Front Right ABS sensor wires so I can wire into the Syvecs. I used to have RLTC, so still have all the + wires tapped into. Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted February 9, 2015 Share Posted February 9, 2015 I think you will find them on the Racelogic site, they are certainly in their instruction manuals that come with the JZA80 kits. If not a multimeter with an extended lead, set to resistance or continuity settings will find the wire. One wire to one side of the ABS sensor connector, then probe the ABS ECU plug. Both sensor connector and ECU connector disconnected from sensor and ECU. One side will be a common ground, the other will be the signal into the ECU. Quote Link to comment Share on other sites More sharing options...
markssupra Posted February 9, 2015 Author Share Posted February 9, 2015 Thanks Chris Quote Link to comment Share on other sites More sharing options...
