uzzyuzzy Posted February 8, 2015 Share Posted February 8, 2015 Just spotted this in one of the threads and was wondering if this is normal, oil from dump valve. Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted February 8, 2015 Share Posted February 8, 2015 What side of the pipework is it on? Turbo or intake manifold? Quote Link to comment Share on other sites More sharing options...
bignum Posted February 8, 2015 Share Posted February 8, 2015 Looks like its fitted in the stock (twins) location, a small amount of oil coming from the bov is normal, if you`re mopping it up daily then there may be a problem. Quote Link to comment Share on other sites More sharing options...
Tommyd16 Posted February 9, 2015 Share Posted February 9, 2015 I think the oil seal has gone in one of my turbos as I'm having the same issue but it's quite bad Quote Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted February 9, 2015 Share Posted February 9, 2015 A small amount is normal, but as said if it always wet with oil on the pipe where it dumps then you may have a turbo seal problem. Quote Link to comment Share on other sites More sharing options...
