why does my supra sound like its going to blow up??
calsupra
The other day i noticed some oil drops under the front end of the supra so i looked under the bonnet and the bottom of the power steering pump looked abit wet. So i topped it up and bled the air out.
When i started her up earlier all was fine until it warmed up then it started to whine really loud and when i revved it or turned the wheel the whining got alot louder.
I made a video of the noise here: https://www.youtube.com/watch?v=E1QS3GmgDok&feature=youtu.be
Take off the reservoir, drain it out and flush it through with petrol or brake cleaner until the flushing agent runs clean. there's a nylon gauze filter in the lower part of the reservoir and it *might* be choked up with sediment. Don't poke at it, or you'll put a hole through it. then air dry, refit and fill with fresh fluid. Top up with engine idling, if it foams up leave it a few hours for air to percolate out, and top again. If this doesn't work it's possibly the pump needs rebuilding. i keep service items in stock, but it's not a job for the kitchen table.
Thanks Chris thats very helpful, if im unsuccessful i will give you call about the service kit.
