ballsdeep Posted February 1, 2015 Share Posted February 1, 2015 (edited) Can't believe I'm writing this but I'm being pressured into buying a family car.. Boooring!!! so I'm looking for some guidance on value since its na-t I can't compare it to the usual cars in the classified. Year: 1995 M Facelift: pre-facelift Mileage: 77k Service history: unfortunately I have no service book, but do have a huge folder of receipts, it's regular serviced and the cam belt, water pump and new thermostat has just been done on Friday by my brother inlaws garage, everything else I have done myself including the turbo conversion. I bought the car in 2007 and I'm the 2nd uk owner, I have the certificate of registration dated 04/07/2005 and every mot certificate to back up the mileage and every tax reminder to show its been my daily car since ownership. Modifications: ENGINE: Xs power manifold modified to fit v-band wastegates wrapped in titanium heat wrap T61 turbo, titanium blanket - 4" k&n filter Precision wastegate pw46 Rx7 550cc injectors cleaned and flow tested with all new seals Toyosport FMIC 3" pipe work SSQV bov (copy) TT FFIM modified to fit na runners, with TT iacv and tps TT cam covers 4" down pipe 4" mid pipe with flexi section welded in Motoria 3" exhaust Walbro 255 fuel pump Fuel damper bypass hose Whifbitz oil catch can Arp carbon fibre cooling panel Brand new ignition leads GEARBOX: W58 5 speed Fidanza flywheel Spec stage 3 clutch Oil was changed at the time of turbo conversion ELECTRICAL: Aem afr gauge Gfb II ebc Brand new Greedy e-manage ultimate ecu wired into patch extension Greedy 3bar map sensor Depo oil temp gauge Depo oil pressure gauge Falcon predictor evo4+ alarm with remote start Tracking device - tracker monitor BODY: Facelift headlights Facelift rear lights J-spec bonnet with uk vent Trd style spoiler with carbon fibre blade Veilside skirts and spats (I have in my possession stock side pods and trim inc front and rear arch trim) bilstein suspension WHEELS: Wheel mania vortex 19" alloys Refurbished a few years ago after the lacquer flaked off so went with a hyper silver dish and black spokes but have been curbed so need re-doing. (Work done in the last 12months) Water pump and rear housing Cambelt Thermostat Slave cylinder refurbished Master cylinder refurbished New o2 sensor J-spec brakes all round refurbished and painted gold New slotted discs all round Fuel filter Oil filter 5w30 fully synthetic oil Power steering fluid Gearbox fluid Aux belt Aux belt tensioner New distributor cap and rotor arm Bkr7s spark plugs Turbo conversion was completed on 09/2013 and mapped by tuning developments, I then I made some changes, injectors, TT FFIM, changed the wg spring to 6psi and had Lyndon aka nodalmighty road map it, here are the results @ 7.5psi Dyno'd 20/12/2014 Bad bits: paint work is looking its age, little dings scratches lacquer fade etc. from what I can see the only bit of rust is on both front wings my plan was to have both sides painted, so doors rear quarters and roof, iv been quoted 1k glass in or £1500 glass out. Also the veilside skirts need to go and the wheels could do with some small repairs More recent and Interior shots to follow tomorrow. Anything iv missed to help value the old girl let me know. Thanks for reading! Edited May 1, 2016 by ballsdeep (see edit history) Link to comment Share on other sites More sharing options...
j_jza80 Posted February 2, 2015 Share Posted February 2, 2015 Should be around £5K. Link to comment Share on other sites More sharing options...
ballsdeep Posted February 2, 2015 Author Share Posted February 2, 2015 (edited) Thanks, I spent that much on the conversion Edited May 1, 2016 by ballsdeep (see edit history) Link to comment Share on other sites More sharing options...
ballsdeep Posted May 1, 2016 Author Share Posted May 1, 2016 Well a year on and im still here but think it might be time to move on.. Prices seem to be on the up and iv made a few changes so where are we at now with NA-t prices? I had tuning developments do some final tweaks to the map last year and it made 385bhp. My very first dyno run [ATTACH=CONFIG]211489[/ATTACH] [ATTACH=CONFIG]211490[/ATTACH] Link to comment Share on other sites More sharing options...
berg Posted May 1, 2016 Share Posted May 1, 2016 Currently people seem to be pricing things to their own value instead of a 'going rate' If it were me id price high and try my luck, finding a decent n/a manual for less than 5-6k is a rarity now so being a nicely spec'd na-t will help They are becoming thin on the ground and theres quite a demand for them so no need to give it away Link to comment Share on other sites More sharing options...
ballsdeep Posted May 1, 2016 Author Share Posted May 1, 2016 This is not a decision I'm taking lightly as you can see from the date on my original post but there's just niggly bits that need doing or bug me and I just can't find the time to make it the car it should be. Problem is I have nothing to compare with, over the time of ownership iv seen 2 supras up close. its very clean underneath but up top the paintwork lets it down in places but I suppose not every supra has had a respray. Then there's the spec clutch which screeches (only when cold) apparently it's common. Link to comment Share on other sites More sharing options...
Supraleeturbo Posted May 1, 2016 Share Posted May 1, 2016 If you want to sell I have a mate looking with cash waiting Link to comment Share on other sites More sharing options...
ballsdeep Posted May 1, 2016 Author Share Posted May 1, 2016 Thanks il keep you in mind but right now I'm not sure what it's worth or where to go after supra ownership.. Nothing's really jumping out at me but I do like the bmw 335i and m5's but both are a little out of budget! I'm finding it hard to find a replacement. Link to comment Share on other sites More sharing options...
Annabella Posted May 1, 2016 Share Posted May 1, 2016 Thanks il keep you in mind but right now I'm not sure what it's worth or where to go after supra ownership.. Nothing's really jumping out at me but I do like the bmw 335i and m5's but both are a little out of budget! I'm finding it hard to find a replacement. You mean you're making it hard to find a replacement Link to comment Share on other sites More sharing options...
ballsdeep Posted May 1, 2016 Author Share Posted May 1, 2016 Is it that obvious.. I know I'd kick myself if i let it go! Link to comment Share on other sites More sharing options...
stevie_b Posted June 5, 2016 Share Posted June 5, 2016 Hi, Random question here: how do you find the stage 3 clutch? Not too harsh? Link to comment Share on other sites More sharing options...
ballsdeep Posted June 5, 2016 Author Share Posted June 5, 2016 No it's perfect but mine does screech when it engages but only on warm up, Apparently it's common. Link to comment Share on other sites More sharing options...
Supraleeturbo Posted June 5, 2016 Share Posted June 5, 2016 You still Selling this Link to comment Share on other sites More sharing options...
Zeiretto Posted June 5, 2016 Share Posted June 5, 2016 Should fetch you around £7k if the only bad thing is the paintwork. The NA-T conversion seems well done, on the picture anyway. Link to comment Share on other sites More sharing options...
