Scott Posted January 31, 2015 Share Posted January 31, 2015 I was thinking 24awg would be fine for pressure sensors, temp sensors, etc. Any thoughts to the contrary? From what I understand 24awg is fine for 5A. I can't see any of the sensors drawing any more than that? Thanks. Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted January 31, 2015 Share Posted January 31, 2015 Can be thinner still, the only sensor with much current draw is the O2 sensor heaters which draw quite a bit. Anything off the 5V reference from the ECU will be drawing milli amps. I'd wory more about copper content of the wire, and insualtion material, some Ebay wire has sod all copper in the conductors. Teflon insulation would be nice, but a PITA to strip without special tools. Quote Link to comment Share on other sites More sharing options...
Scott Posted February 1, 2015 Author Share Posted February 1, 2015 Can be thinner still, the only sensor with much current draw is the O2 sensor heaters which draw quite a bit. Anything off the 5V reference from the ECU will be drawing milli amps. I'd wory more about copper content of the wire, and insualtion material, some Ebay wire has sod all copper in the conductors. Teflon insulation would be nice, but a PITA to strip without special tools. Thanks for the input Chris. I was thinking that but wanted to be sure. Will see what quality of wire I can pick up from eBay. I've ordered a sample pack from a seller so I'll get it on the megger and see how much it heats up I've already sorted out the wideband with something a little more heavy duty so that side of things should be OK. I'm going to sheath all of the wires that i'm using anyway, so they should be relatively safe in and around the bay, I'll be careful how I'm placing them Quote Link to comment Share on other sites More sharing options...
