Supraleeturbo Posted September 2, 2016 Share Posted September 2, 2016 New manifold, 90mm throttle body, 3/4" high flow fuel rail http://i263.photobucket.com/albums/ii125/bergofski/Single%20build/1020551C-F87F-4792-92EE-403816C41D54.jpg http://i263.photobucket.com/albums/ii125/bergofski/Single%20build/44BA1383-569E-4BF8-9C30-CD5C20190D39.jpg Assembled with fuel injectors http://i263.photobucket.com/albums/ii125/bergofski/Single%20build/D4D3DD7B-0EA3-48A1-AF33-558572837410.jpg http://i263.photobucket.com/albums/ii125/bergofski/Single%20build/95F5E3C6-0675-45E8-AB6F-6C91967F008B.jpg http://i263.photobucket.com/albums/ii125/bergofski/Single%20build/CA140C9C-6974-4E30-9816-E69F225FCDDA.jpg /QUOTE] Where's this from and how much please mate feel free to pm me Link to comment Share on other sites More sharing options...
Samurai 20V Posted September 2, 2016 Share Posted September 2, 2016 A small amount should be yer, im hoping to get the engine built next year so can open up the full potential then Why would large amounts of ethanol not be good on a stock block? Link to comment Share on other sites More sharing options...
berg Posted September 2, 2016 Author Share Posted September 2, 2016 Where's this from and how much please mate feel free to pm me Ill pm you Why would large amounts of ethanol not be good on a stock block? Ive been told by tuner that running high power on the stock block with ethanol can be dangerous for the rods due to the extra torque so I've been advised to change rods and rod bolts before going mad Also to change to head stud kit as it can cause the head to lift No point risking it Link to comment Share on other sites More sharing options...
Samurai 20V Posted September 2, 2016 Share Posted September 2, 2016 Ill pm you Ive been told by tuner that running high power on the stock block with ethanol can be dangerous for the rods due to the extra torque so I've been advised to change rods and rod bolts before going mad Also to change to head stud kit as it can cause the head to lift No point risking it /QUOTE] Ok cool, makes sense.. Link to comment Share on other sites More sharing options...
a98pmalcolm Posted September 2, 2016 Share Posted September 2, 2016 What is the max lb ft of torque can a stock GTE engine take? I know max bhp is 750 but I have never seen anything about toque Link to comment Share on other sites More sharing options...
TheTurtleshead Posted September 2, 2016 Share Posted September 2, 2016 Plazmaman intake? Link to comment Share on other sites More sharing options...
Dim Sum Posted September 2, 2016 Share Posted September 2, 2016 What is the max lb ft of torque can a stock GTE engine take? I know max bhp is 750 but I have never seen anything about toque I think around 600lbs of torque is probably what a stock bottom block will take. Maybe a little more but then it depends how hard and often you drive it i guess. Link to comment Share on other sites More sharing options...
wrighty338 Posted September 2, 2016 Share Posted September 2, 2016 shiny bits Link to comment Share on other sites More sharing options...
berg Posted September 4, 2016 Author Share Posted September 4, 2016 What is the max lb ft of torque can a stock GTE engine take? I know max bhp is 750 but I have never seen anything about toque Is yours still on stock engine? Plazmaman intake? Its basically the same manifold kit you can buy from SSI performance just slightly cheaper as it doesn't have the uk price inflation due to me ordering direct from abroad Made to order, custom spec etc can even be made for dual fuel rail etc Very good build quality Link to comment Share on other sites More sharing options...
sebas Posted September 4, 2016 Share Posted September 4, 2016 (edited) Lovely manifold, I am considering buying one of these for my car as the price is ok. Can You post more photos please? especially of that part that's bolted to the engine. Thank you Edited September 4, 2016 by sebas (see edit history) Link to comment Share on other sites More sharing options...
berg Posted September 5, 2016 Author Share Posted September 5, 2016 Lovely manifold, I am considering buying one of these for my car as the price is ok. Can You post more photos please? especially of that part that's bolted to the engine. Thank you I can take photos, but what exactly are you wanting to see? Just the flange that bolts to the head? Link to comment Share on other sites More sharing options...
sebas Posted September 5, 2016 Share Posted September 5, 2016 I saw that some of the aftermarket/custom manifolds have grooves for O-rings and some are just flush finished and you need some gaskets to seal them properly. And I really like pictures Link to comment Share on other sites More sharing options...
berg Posted September 5, 2016 Author Share Posted September 5, 2016 I saw that some of the aftermarket/custom manifolds have grooves for O-rings and some are just flush finished and you need some gaskets to seal them properly. And I really like pictures This one has grooves for o-rings, but ive spoken with the manufacturer and a stock gasket will work just fine if you dont want to use the o-rings I can take pics should you need any Link to comment Share on other sites More sharing options...
sebas Posted September 6, 2016 Share Posted September 6, 2016 This one has grooves for o-rings, but ive spoken with the manufacturer and a stock gasket will work just fine if you dont want to use the o-rings I can take pics should you need any that's not necessary, thank you for info how it's made! Sebastian Link to comment Share on other sites More sharing options...
berg Posted September 16, 2016 Author Share Posted September 16, 2016 Last few pieces have arrived Link G4+ Supra Link ecu I have the expansion loom, 3 bar map sensor, IAT sensor and Link knock sensor to come also Also have some Whifbitz 264 cams on the way too which should hopefully make a difference when mapping is done Now to fit it all and hopefully have it mapped before Japshow Finale As the Link ecu needs the top and bottom covers from a stock ecu, ive ripped apart an old na auto ecu i had lying around and will use the covers from that, my friend is just starting up a powder coating business so hes going to paint the covers gloss black free of charge just to give it that extra touch Link to comment Share on other sites More sharing options...
ripped_fear Posted September 17, 2016 Share Posted September 17, 2016 Nice update. Who's mapping the link ecu? Link to comment Share on other sites More sharing options...
berg Posted September 17, 2016 Author Share Posted September 17, 2016 Nice update. Who's mapping the link ecu? /QUOTE] Mapping will be done by Greg at ProTuner Link to comment Share on other sites More sharing options...
berg Posted September 17, 2016 Author Share Posted September 17, 2016 264 cams Link to comment Share on other sites More sharing options...
Sheefa Posted September 17, 2016 Share Posted September 17, 2016 Mapping will be done by Greg at ProTuner Best man for the job mate. Well done. I'm seeing Greg later in the year for a few tweaks too Link to comment Share on other sites More sharing options...
ripped_fear Posted September 17, 2016 Share Posted September 17, 2016 Mapping will be done by Greg at ProTuner Link to comment Share on other sites More sharing options...
berg Posted September 26, 2016 Author Share Posted September 26, 2016 So today i decided to fit the Whifbitz 264 cams Not many pictures here but started the strip down Exhaust cam fitted Both cams fitted, belt back on and all timed perfectly My next little project was the cam covers I wanted to use AN- fittings for these, but once the fittings are welded on and a 90 degree fitting is on i dont like how far the stick out, most people have them pushed into the turbo blanket as they are so wide So i decided rather than weld, i would tap the holes and use a pair of screw in 90 degree fittings instead No drilling is needed as a 3/8"NPT tap fits the exhaust cover perfectly and a 1/2"NPT tap fits the inlet cam cover perfectly So 2 taps 2 fittings which i had to have imported as i couldnt find these in the UK Exhaust cam cover tapped Inlet cam cover mid way through & a test fit of the threads Once completed i think it looks pretty darn good In terms of swarf, covers have been fully flushed through and an inspection camera inserted to make sure its all good If anyone tries it, i would advise using a camera once flushed, or if you cant access one then it may be a good idea to drill the baffles out and clean that way Catch can is also getting some love Its only a Whifbitz stage one so rather than sell and fork out for a new one Ive drilled holes out and 2 new fittings are currently being welded on as we speak Ready to smooth the holes, de-bur and weld on Link to comment Share on other sites More sharing options...
berg Posted September 26, 2016 Author Share Posted September 26, 2016 Also my mate painted the ecu covers for me so being bored one night i decided to add a bit of carbon and a nice dome badge that came with it Pointless as its hidden, but it will look good under the carpet Link to comment Share on other sites More sharing options...
Supraleeturbo Posted September 26, 2016 Share Posted September 26, 2016 Lovely coming on well pal can't wait to see the final results Link to comment Share on other sites More sharing options...
berg Posted September 26, 2016 Author Share Posted September 26, 2016 (edited) Lovely coming on well pal can't wait to see the final results Cheers mate, diff going in tomorrow along with intake manifold and fuel system Edited September 26, 2016 by berg (see edit history) Link to comment Share on other sites More sharing options...
Parm_93 Posted September 27, 2016 Share Posted September 27, 2016 Looking good mate, did you use any type of gasket maker on the AN fittings? Link to comment Share on other sites More sharing options...
