supra N/A (problem) please help
bananasupra
I had similar symptoms when my Mines ecu played up. I was driving along fine, then the red warning light came on and it struggled to maintain revs etc, even under throttle power and was running rough with a jumpy idle.
Does it struggle to even turn over without your foot on the accelerator?
Due to the time of year the cold 'may' be making it play up. I've currently got the in car door locks locking, but not unlocking, cold issue :rolleyes:
If you get a spare moment remove the ecu (passenger footwell) and check it's done up tight/check for damp/condensation etc. Being old it could be a simple dry solder joint or the aforementioned..... along with another issue.
I was lucky as I kept my stock ecu when I brought the mines, when mine did this I swapped it over and thankfully everything's been fine since. Is there anyone local that would let you try their ecu out to rule it out as a potential problem?
