2JZMKIV Posted January 25, 2015 Share Posted January 25, 2015 I own a 6 speed bpu TT with this SARD ANALYSE ecu bought the car about 4 months ago from japan. i will list the known mods: HKS induction kit evc 4 boost controller turbos in ttc mode ats & across twin disc carbon clutch hks hi-po type s exhaust Car has no speed limit no rev limit it revved up to 8200 i didnt push it more as it is already too much for the stock engine ( assuming its stock inside) i have no idea what this ecu does but surely it has an agressive map i can tell and we only have 98 ron in cyprus so i dont know if this ecu will cause me trouble does anyone know anything about this ecu ? Quote Link to comment Share on other sites More sharing options...
Mk4Gaz Posted January 25, 2015 Share Posted January 25, 2015 It's the same as a blitz access or mines ecu. Basically they're pre programmed for mods such as: Double decat Boost increase Fuel cut Rev limit raised More aggressive fuelling and timing To find out exactly what yours has been mapped for, can be found out by emailing sard with the ecu number - in your case, it appears to be 1848 - although I could be wrong. You may get lucky and get a response, I know people in the past have had luck with their blitz and mines ecus Quote Link to comment Share on other sites More sharing options...
