jza800 Posted January 21, 2015 Share Posted January 21, 2015 I now got my gizzmo ms2 mountet to my sub, and i have to adjust the voltage to the correct fuel cut voltage level.. i have heard the voltage for fuelcut on 93-95 is 4.3v and 96 to 98 is 4.1v, and as i have the non vvti engine is my car.. should i then put the voltage on 4.3v??? or should i put it a little lower or higere Quote Link to comment Share on other sites More sharing options...
heckler Posted January 21, 2015 Share Posted January 21, 2015 what do the instructions say? Quote Link to comment Share on other sites More sharing options...
jza800 Posted January 21, 2015 Author Share Posted January 21, 2015 nothing Quote Link to comment Share on other sites More sharing options...
heckler Posted January 21, 2015 Share Posted January 21, 2015 what the name/model of your "gizzmo"? Quote Link to comment Share on other sites More sharing options...
jza800 Posted January 22, 2015 Author Share Posted January 22, 2015 Gizzmo ms2 Quote Link to comment Share on other sites More sharing options...
jza800 Posted January 22, 2015 Author Share Posted January 22, 2015 ??? Quote Link to comment Share on other sites More sharing options...
Mk4Gaz Posted January 22, 2015 Share Posted January 22, 2015 I don't think there is a simple answer, it's likely to take a bit of trial and error. Set it a bit lower than you think, and see what boost pressure you reach when the fuel cut kicks in. If you require more boost, just increase the setting until it cuts slightly higher than your target boost. Or pay a small fee, and have a tuner set it up on a rolling road Quote Link to comment Share on other sites More sharing options...
heckler Posted January 23, 2015 Share Posted January 23, 2015 Right. Done some digging for you. 4.3v Quote Link to comment Share on other sites More sharing options...
jza800 Posted January 23, 2015 Author Share Posted January 23, 2015 I say thanks alot for your help. Quote Link to comment Share on other sites More sharing options...
heckler Posted January 23, 2015 Share Posted January 23, 2015 It may need a little tweak to get it spot on. How are you setting it up? Multi meter? Quote Link to comment Share on other sites More sharing options...
jza800 Posted January 23, 2015 Author Share Posted January 23, 2015 no, you can set it up in the fcd menu on the ms-2, there you can choose the voltage it shuold clamp the voltage... Quote Link to comment Share on other sites More sharing options...
