Jellybean Posted January 19, 2015 Share Posted January 19, 2015 Hey I am having issues mounting the seats to the rails, if I tighten the rail to the seat , the slider wont work as it is slight putting the rial out of alignment Any idea's? I got the Mo rails , difference between these and the Ro rails is you get an extra piece of hardware you can use (two plates) I cannot use these mounting plates either as the rear of the seat will seat on top of the plate not flush , due to the seats base design , and the front of the seat has no mounting holes to coincide with the plates mounting points, they are not an option Pics are coming Link to comment Share on other sites More sharing options...
Jellybean Posted January 19, 2015 Author Share Posted January 19, 2015 Link to comment Share on other sites More sharing options...
Jellybean Posted January 19, 2015 Author Share Posted January 19, 2015 What I am thinking i to use a spacer , washer ? Link to comment Share on other sites More sharing options...
Jellybean Posted January 19, 2015 Author Share Posted January 19, 2015 Just seen this http://www.driftmotion.com/product-p/dm2935.htm This seat spacer is 1/4 inch thick aluminum powder coated black, and is the length and width of the Recaro Non-tabbed slider. The spacer also includes predrilled slots so putting them between the slider and the seat bracket is a sinch with some longer hardware. We created these spacers to solve an issue with the Recaro Sportster CS, Style, Sport, or Trend seats where the bottom of the seat hangs down lower then the sliders so can contact the bracket. Raising them 1/4 inch solves the issue. The spacers are also ideal for raising any seat that sits lower then desired and can be used with other major brands of sliders like Sparco & OMP. They can also be used without sliders although in some cases drilling additional holes may be required. Link to comment Share on other sites More sharing options...
Jellybean Posted January 19, 2015 Author Share Posted January 19, 2015 Would it be safe to use some washers between the seat and seat rail? Link to comment Share on other sites More sharing options...
johnd-mkiv Posted January 19, 2015 Share Posted January 19, 2015 Make sure you use large penny washers to spread the load, mount the rails and pack out until you are not bowing the runners when tightening. Link to comment Share on other sites More sharing options...
Jellybean Posted January 19, 2015 Author Share Posted January 19, 2015 Make sure you use large penny washers to spread the load, mount the rails and pack out until you are not bowing the runners when tightening. Cool beans will do Thanks Link to comment Share on other sites More sharing options...
MATT RR Posted January 20, 2015 Share Posted January 20, 2015 (edited) Hi mate, I had the same issue but different Recaro seats, if you look at the hand rail it angles one way (supposed to be down), mine were the wrong way, if you remove it, flip it over the other way then it points down and works fine! took me ages to figure it out It may be this issue or maybe not but worth a checking! Edited January 20, 2015 by MATT RR (see edit history) Link to comment Share on other sites More sharing options...
Jellybean Posted January 20, 2015 Author Share Posted January 20, 2015 I am nearly sure the rail is handle is angled down When you bolt up the rails it does not keep them uniform ,it bends them so when you try to use the slider , the rail is clampped down on it , preventing it from sliding Link to comment Share on other sites More sharing options...
Jellybean Posted January 20, 2015 Author Share Posted January 20, 2015 Its working , might try it with 3 washers Hope it sits low enough in the car Link to comment Share on other sites More sharing options...
Guest Nicholas Posted January 20, 2015 Share Posted January 20, 2015 Its working , might try it with 3 washers Hope it sits low enough in the car http://i1207.photobucket.com/albums/bb469/clodola/C828B4EB-713F-47E6-8878-7A05DA070FF4_zpsqrtkwegl.jpg http://i1207.photobucket.com/albums/bb469/clodola/0138BDE0-12EF-49FF-BAA2-996151DE7E4A_zpsh9d9hpvl.jpg Blimey, sorry to hear you're having trouble. Are you happy with that? looks like a bodge job to me. I certainly wouldn't be happy. Link to comment Share on other sites More sharing options...
Jellybean Posted January 20, 2015 Author Share Posted January 20, 2015 Blimey, sorry to hear you're having trouble. Are you happy with that? looks like a bodge job to me. I certainly wouldn't be happy. I am not happy , but no other way to attach the seats to the rails , few guys in the US have the seats and this is how you do it Its safe and you wont see it Link to comment Share on other sites More sharing options...
